getting the best out my engine?!
Remove the starter shroud & the head. Stand the engine so the piston is pointing straight up & pour a small amount of oil around the top of the piston. Let it stand like that overnight &, tomorrow, try turning the flywheel by hand.
Solidshot
Stupid question but what oil? As in the oil I'd usually put in the engine or just any old oil? What about WD40?
Solidshot
Ahh this thing is going to need a rebuild it's been friggin tortured! Just spoke to the guy that used to own it, he never changed the oil, all he ever did was fill the tank n tires up and rag the $h!t out of it! Gah! I guess this is what I brought the thing for in the first place!
r_chez_08
Should be in the shop...
Cornwall, UK
Look at it this way- What a great oppurtunity! You now get to tear down the engine without worrying about damaging it further.
If you are lucky, it may not need any parts. If you are unlucky, a new rod and piston with rings, and a cylinder hone may be needed.
Solidshot
So when I disassemble the block, assuming the piston is still seized up how difficult is it going to be other out? Am I looking at a few squirts of WD40 and some elbow grease? Or am I looking at plasma cutters, nuclear bombs and a **** load of resistance? Also how do I polish the
Port? I saw some kid on YouTube use a dremel and some kind of cutting head?
Solidshot
Does anyone know of video showing how to do it on a small power engine, like a gx140? or something simular?
Gadzooks! Folks like that shouldn't be allowed to reproduce!:censored: Dimwits like that are the reason we have these stupid low-oil sensors...
Solidshot
Yeah was kinda awkward talking to him and trying not to flip out! But like said above I guess now I have the ideal opportunity to learn all about how it works and how to fix the engine, so be prepared for a barrage of stupid and amateur questions lol :)
r_chez_08
Cornwall, UK
You will go through many many heads to do a decent port job. However, here are some tips-
1. Match the gasket to the port if there is any overlap.
2. Smooth any rough casting.
3. See the 90* angle under the valve? Try and make this into the largest radius possible.
Do some searching on Bob's 4 cycle. You do not want to really enlarge the ports because you will loose velocity with the stock valves.
Solidshot
Sheeze, got me some reading and note taking to do when i gets home from work tomorrow, Im hoping to starting ripping it down Saturday, before i start i want to check that im not going to need something specialized? Like ive got shed loads of WD40, carb cleaner, Gunk and over oil+grease remover, Ive got all the basic tools, sockets, spanners, open and closed end'd. Am i going to need anything specifically? Also where is it a good/bad idea to start certain things?
Like when it comes to cleaning the internals? Can i just spray anything in there to clean it out? Sorry for these somewhat ameture questions, im just trying to get the know how before i go in a balls it up anymore.
Also one more thing i should add, i was speaking to my dad, and i said that the engine was siezed. He had said that if i can pull the cord out and the flywheel still turn it wasnt siezed? This true? I mean when i pull the cord its stiff but it still moves? And the fly wheel still turns?
souperman000
Westlake Village, CA
Do you own/have access to a torque wrench? It will be a necessity putting everything back to gether. Also have a specs sheet or a manual nearby to tell you how to tighten the bolts etc.
The flywheel thing you are feeling is probably just compression....
Have a good read of this thread. This is landuse's first rebuild (which still isn't finished :toetap05:). It contains a barrage of useful info
Can you believe it. The guy doing the adaptor for me said he would do it at the beginning of this week. Guess what?? He says his PC crashed with all their office accounting software on it, and he has been busy sorting that out.
I am itching to continue though. Oh well......
Solidshot
I have a socket wrench not a torque wrench I don't think, the manual I'm sure I can find somewhere on the net:)
Check that a rocker hasnt fallen off the valve under the rocker cover.
Yeah will give that a check! In the unlikely event that there is a load of dirt in there what's the best to use to clean it out?
Solidshot
Right a thought I've just had whilst eating my lunch lol I have a replacement engine on the way, if I could get the governor out of both, and do the same mods to both the engines would it be possible to put another sprocket on the axel and have another engine on the kart? Just a thought I'm bouncing about for some ideas assuming on the fact of course that i can this engine working again!:)
