at the store, need an opinion
beansdaddy78
JR. Member
Carbondale IL.
I'm standing in front of a variety of max torque clutches, they only have 10 tooth and 12 tooth. Which should I get if im wanting a higher top speed. I assume It's the 12 tooth but I wanted to make sure. Any help would be appreciated
scarletvw
Minnesota
smaller the tooth off of the motor the more torque the engine will have but lower top speed. The larger the amount of teeth the faster it will go but less acceleration.
If you get too large of a front sprocket for your cart setup you will burn up the clutch.
What was previously on the cart and did it work alright?
Blazkowiez
Kart Aficionado
Houston, Texas
Assuming you are looking at 10 tooth and 12 tooth 3/4" bore clutches these are not interchangeable. The 10 tooth is for 1/2" pitch chains, most commonly #40, #41, and #420. The 12 tooth is for 3/8" pitch chains in karting this refers to #35 chain.
Hahahaha! How long are you willing to stand there awaiting responses?
Get the 12T for a higher overall ratio. I may be splitting hairs but,
An engine having more torque because of sprocket size is not at all accurate. Gearing down will result in more torque at the wheel. The engine does not change. In fact, the engine sees less load, it does not develop more torque.
beansdaddy78
JR. Member
Carbondale IL.
LOL, I wondered around the store , before I had a 11 tooth I believe. Cab max torque clutches be rebuilt?
Blazkowiez
Kart Aficionado
Houston, Texas
Yes, they can be rebuilt.
MaxTorque sells both replacement springs and bushings which typically are the things which break first.
If you had an 11 tooth clutch before what bore is the shaft on your engine?
beansdaddy78
JR. Member
Carbondale IL.
i believe it is 3/4. im pretty sure all the clutches at the store were the same size bore, the 10 and 12 i think they would both fit on the same motor. since you mentioned it im going to check and see if they are different. i appreciate everybodies quick responses.
also does anybody know where there might be a video or walkthrough of how to rebuild a clutch. also are the parts fairly cheap? or is it cheaper by much to rebuild?
beansdaddy78
JR. Member
Carbondale IL.
well i just realized im plain stupid. i took off the old clutch and when i did i realized my buddy who rode it didnt check the front sprocket when the chain came off, he just put it back onto the large sprocket and tried to ride., bad news, im an idiot. good news i can return the new clutch because the old one works just fine, and i counted its a 12 tooth, and my other sprocket is a 63 tooth. with a 5 hp briggs
