Manco 5HP Fun Power problems
MARGR4V3Z
MICHIGAN
Manco 5HP Briggs Fun Power Problems
It likes to stall out when I come to a stop after going pretty fast. So I cleaned the carb and replaced gasket the other day and it still does the exact same thing, I have messed with the idle screw and mixture screw and that doesnt help. I have to veryyyy slowly press the gas for it to go without dying out. I cant punch it from a dead stop or it will die. Not every time but fairly often. What would cause it to do that?
Nodroz
Belgium (Europe)
If your engine isn't responding to your throttle (when you go full throttle, the engine dies) then you need to adjust the air screw. Start from 0 to 1.5 turns out.
Turn your idle screw until the engine runs smoothly. Not too low, not too high.
MARGR4V3Z
MICHIGAN
Ok I have tried every combination with the idle and air screw. When I turn the air screw anything past .5 of a turn it doesnt idle good at all. So it has to be screwed in all the way to idle right. I dont know what to do now. Its really annoying having the Kart die out every time it slow down from going fast or just try to gas it.
r_chez_08
Should be in the shop...
Cornwall, UK
Sounds like it is leaning out. How does the engine run when you partially choke it? Worse, or do the problems go?
I do not know what these carbs are like, but if there is an idle jet, and the motor runs better slightly choked, I would richen the jet.
MARGR4V3Z
MICHIGAN
When its partially choke it does run but hesitates when im driving. It still wants to kill it when you gun the throttle.
There is only an idle screw and air screw.
tundrabeagle3
Ca
i was having the same problems when i got a used fun power briggs i was having air leaks. i fixed it by making two gakets for the carb to gas tank, tightening the carb bolts down with loctite. the adjusting the idle speed in is lean out is rich you want about 1 1/2 to 2 turns out from all the way in. also make sure your crankcase breather is connected to the carb.
MARGR4V3Z
MICHIGAN
Well I tested for a leak and couldn't find one to my knowledge, sprayed carb cleaner around carb gaskets and it didn't jump while idling. Could it just be a gummed up carb even after I cleaned it?
Did you check the diaphram on the side of the carb? Because they're a suction feed, these carbs have an internal pump. Could be that the pump is not functioning 100%
MARGR4V3Z
MICHIGAN
When I cleaned the Carb I did take that piece apart and I guess I should have changed the Diaphragm when I got a new carb to tank gasket but I didn't. So that might be the problem. I will change that and see what happens.
MARGR4V3Z
MICHIGAN
For the few dollars you'll spend on it, it can't hurt
Ok so I spend a few dollars and got a new pump diaphragm like a week ago and re-cleaned the carb with carb cleaner and compressed air and a wire. It run like a bat out of hell after that for I would say 4 hours of riding and now its back to square one. Want to die out when you give it gas. What could be causing this? Could the carb be bad? Let me know!
When you cleaned the carb, did you also clean out your tank? It's very possible that shrapnel/dirt is being picked up from the tank & blocking the carb.
MARGR4V3Z
MICHIGAN
Well as best as I could. I took out that foam liner that was in there. I had to siphon the gas out and I used some carb cleaner but I couldnt take the tank off completely because the bolt that holds it on their is no way to get to it without taking the engine off. That filter that is at the bottom of that tube must be getting caked with dirt and not letting gas flow easily is what im thinking.
Blazkowiez
Kart Aficionado
Houston, Texas
If it comes down to the pick-up tube rotting out you can use a drop pick-up out of a weed eater, the small line and filter works fantastic.
MARGR4V3Z
MICHIGAN
Oh I like that idea, doesnt the pickup tube come off the brass fitting somehow? Then I would just used weed whip gas line and a filter off the brass fitting?
Blazkowiez
Kart Aficionado
Houston, Texas
Yep. They have a filter with a weight that will keep it at the bottom of the tank. It should filter out minor rust and debris.
tundrabeagle3
Ca
i would just clean the pick up tube with a air compressor, then hammer it with a nail on top to open up the top of the tube and jam it into the bottom of the carb. then take out the carb to tank bolts out and put loctite on every bolt and buy or make a carb to tank gasket if yours looks worn or torn.I had the same problem and it is caused by an air leak in the carb, the vibration from the motor can loosen the carb to tank bolts and cause and air leak. loctite keeps the bolts in place , tightly to prevent any air leaks.
Blazkowiez
Kart Aficionado
Houston, Texas
Sorry to hear about your troubles tundra, however I've never heard of a single properly torqued bolt on a briggs tank vibrating loose. Were you using a standard briggs gasket or something home made?
tundrabeagle3
Ca
I have no governor and no suspension on the small mini bike that has the 5 hp briggs. It vibrates like crazy when I rev it and I also ride it offroad so things tend to come loose. I make two gaskets out of gas and oil proof gasket rubber material from autozone and stack them on top of each other. i then put loctite on every bolt and screw them down tight with an impact drill and have not had any air leak problems since.
Thats a brilliant idea. Thanks Blaz!!
I also had my carb vibrate loose on my 3.5HP Briggs. I then also decided to use loctite, and it works fine now
