Hello, I am wondering if there is a clutch that will engage at very low rpm?
Or
Is there a way to mount a transmission to a gx 200.
Basically I want neutral and forward and it will be driving a drive shaft
any help would be much appreciated
Most clutches come set to engage around 1800-2000rpm, and are fully engaged by 2200rpm. The stock idle on a gx200 is ~1400rpm, and you would be pushed to get it much lower.
May I know why you would like a clutch that engages at low rpm? Keep in mind, as Fabroman says that if the engagement speed is too low, your clutch will start engaging on engine idle, causing your gokart to drive away without you on it.
how about a belt drive cent clutch ( obviously with sotfer springs) and a hand operated belt tensioner ?? low engagement of clutch AND the ability to totally dis-engage clutch= neutral !
or eliminate the clutch altogether and just go with a hand operated tensioner ?( with a lever on a pulley and fulcrum) not sure if i'm explaining it right...but i can easily see it in my head ! LOL !
