are these carb's able to be swapped?
beansdaddy78
JR. Member
Carbondale IL.
I have a 5hp briggs on my kart that won't start. Just Saturday and Sunday I was cruising chirping birdies and picking up chicks, and now it just won't start up. So i want to swap carbs from a 3-3.5 briggs to a 5hp briggs
My biggest question is, Can it be done?
To my untrained eye they look the same except the carb from the smaller HP motor is newer and has the mount for the newer style rectangular air cleaner. The 5hp motor is ancient and came with the cylinder style air cleaner. To me the two carbs look like they will swap but do you think so?
Im standing outside hoping to get this wrapped up soon so that i can ride for a bit before my daughter wakes up. So any help would be greatly appreciated. I'm going to try to ad a pic or two, if they are not in this post they will be in the very next in just a few minutes
fowler
Bullsbrook West Aus
To measure if they ate the same u must first measure the bore dia of both carbs
Then remove the bowl and check the keys are the same size
Also measure the bolt pattern on each
That will tell u if they are the same
They are proberly the same carb but they may have put a bigger jet in the 5hp to give it the extra go
This will cause the engine to run poorly
Have u tryed to clean the 3.5hp carb
There may be a far simpler fix to your issue
Hey, if it bolts up give it a go. There is no harm in trying. If it is not working at the moment you might as well try it
Are you sure it is the carb that is giving you problems though
scarletvw
Minnesota
If you're talking about using a 5hp motor with a 3-3.5hp carb, it should work, but it wont run the best, too lean. You'd need to re-jet the carb to get the proper amount of fuel.
I would check out your 5hp carb first and make sure the jet is clean and that everything else is clean before switching out to a smaller carb though.
beansdaddy78
JR. Member
Carbondale IL.
Not 100% sure. I tried rtv'ing tye head gasket before I asked if it was ok.
I have another briggs 5 HP but the cylinder wall has a few minor scratches (minor to me is probably really major). Is that motir worth trying?
Why don't you just clean the carb that you say is faulty? Have you checked that the diaphram is OK? I boiled my carb just like that one in lemon juice and it came out better than new
beansdaddy78
JR. Member
Carbondale IL.
How much lemon juice did you boil it in? Did you boil the carb while it was put together or in pieces?
Have a look here
How to clean a carburetor the right way (with lemon juice)
http://ezinearticles.com/?How-to-Clean-a-Motorcycle-Carburetor,-The-Right-Way&id=1460030
http://www.diygokarts.com/vb/showthread.php?t=11976&highlight=lemon+juice
When I did mine, I took everything apart that I could and stuck it all in a pot. I used concentrated lemon juice with a some water. You can buy fresh juice in some shops though. You got to have enough so that the carb is immersed in it.
Don't put the diaphram or any plastic parts in though. Clean them seperate.
These links will show you how to clean as well. I did both
Briggs Pulse Jet Carb Operation and Disassembling
http://outdoorpowerinfo.com/repairs/briggs_pulsa-jet_horiz_adj.asp
http://outdoorpowerinfo.com/repairs/briggs_pulsa-jet_horiz_fixed.asp
http://www.compgoparts.com/technicalresources/briggscarburetors.asp
beansdaddy78
JR. Member
Carbondale IL.
Lol, just pulled the carb from the tank andthe filter was 98.2% covered with debris, would that be enough to cause it to only slightly fire with carb cleaner sprayed in the carb?
Also I was wondering if spraying carb cleaner in the carb to get it to fire is bad?
fowler
Bullsbrook West Aus
It's not bad but it won't achieve anything
U need to strip it down and properly clean it
It will only take 1 peice of sand to stop the engine dead
scarletvw
Minnesota
Have a look here
Those are some awesome links. I'm going to use the Lemon idea on some smaller 2 stroke Walbro carbs.
Thats why I posted the links about the pulse jet carbs. It shows you how to poke out all the holes that need to be clear. When I did mine, I used a combination of the two, as well as using a compressor to blow through all the holes/jets
