hoping for a little help
beansdaddy78
JR. Member
Carbondale IL.
hey guys, im trying to do anything that i can to make my motor run a bit better and if possible with a bit more power. i have a briggs and stratton 5hp model 130202. what i was hoping to find out is what can i do free modifications to the motor with a dremel, i thought i heard something about taking the cap off the cylinder where the spark plugs go in and doing some grinding with a dremel, problem is i have no idea where or how much to take off and what to do to make sure i dont ruin this motor, at the moment its my only running kart motor i have two other 5 hp motors that are down right now. want to fix those soon as i get this one buttoned up , im pulling an all nighter to work on these so hoping someone else is a night owl and may be able to give me some mod advice here are pics of the parts im wanting to fix now, i removed the governer today so this was next on my list
beansdaddy78
JR. Member
Carbondale IL.
lol ooops forgot the pics here they are for real this time, i hope!
beansdaddy78
JR. Member
Carbondale IL.
Have a look at this thread. I think he is speaking about the same engine as what you have
http://www.diygokarts.com/vb/showthread.php?t=1583
You could hone your bore and lap your valves as well
i understand what they mean but i seriously just dont know where i use the dremel and do i have to remove the piston and valves? im nervous that it may be over my head and this motor somewhat ran when i took it off well it did only start on choke and die when id give gas but could go about 20 feet when feathering the choke and gas. any chance you can explain on my pic where i use the dremel and how far and where not to go with the dremel. im sorry im just super worried ill richard the whole motor up and i want to be successful. thanks for your help sir
beansdaddy78
JR. Member
Carbondale IL.
twas just carbon, i hope i was supposed to remove it cause she is clean as a whistle, it might had been a bith slick or had some slight oil but i figured it was unburned fuel or something im not sure, guess ill find out when and if the motor dies
beansdaddy78
JR. Member
Carbondale IL.
i was having alot of probs starting it, and it would only start on choke, not sure if that would cause it to leave stuff int he chamber i have no idea i am completely ignorant on the subject but hope to get educated soon, here
beansdaddy78
JR. Member
Carbondale IL.
im screwed i have no idea how im ever gonna get this spring back in there and redone, and i cant get the dang spool off so i can try to replace it with a newer used one. im fudged
beansdaddy78
JR. Member
Carbondale IL.
Hey anderkart, what i really need to know is , how to remove the entire flywheel from a briggs and stratton 5hp model number 130202 and i wanna replace it with the flywheel and pull starter of of a slightly newer 135212 they are basically the same motor with just a couple differneces i think. let me know if you got any place with links or something to show me my exact motor and how to pull the flywheel or how to put the spool back on with the ballbearings that rolled out
Every engine ever built will create a carbon build up in the combustion chamber; removing it is healthy. Letting it build up excessively creates "hot spots" which causes pereignition.
beansdaddy78
JR. Member
Carbondale IL.
Is there any reason you want to change the flywheel?
when i was taking the cover off the flywheel the spring sprung and i cannot get it back in there, i was able to get the motor to run without even using the choke for once, a good cleaning helped i guess. so i cant get the cover back on with the recoil part so the string flings around violently without the cover on it and now that i took off that piece with the ball bearings in it im screwed cause i have tried but cant get them back into their slots and the cover back on them. nobody not even briggs and stratton knows jack about this motor, its kinda depressing, im stuck between a rock and a hard place. im excited cause the motor sounded great when i did fire it up
beansdaddy78
JR. Member
Carbondale IL.
cool, i got it all clean and pretty, i was gonna try to port and polish until i realized i had no idea what i was doing so i stopped put the motor back together and yay i just got those **** balls back into the flywheel, i havnt seen another motor set up quite like this briggs flywheel it has a shaft that comes out of the flywheel. now i gotta either load the spring back in there or find a way to leave the cover off and keep the string from hitting me. can i cut the string and wrap it around the spool and pull it and rewrap each time so that i dont have the string flailing around.
I thought I mentioned that, must've been in your other thread...
Now that you have the spool off, can you fit another shroud to it? They should all be pretty similar
beansdaddy78
JR. Member
Carbondale IL.
no they just wont fit, i have two others and i have tried to make them fit but they wont, in the pic im about to post youll see what i mean, instead of that cup like piece of metal on most 5hp briggs, mine has a part that has six ball barrings in it and i cannot get it to come out, it took me forever just to get them back in. but here is a pic of my flywheel the part im having probs with. oh also how do i get a valve out, i got a stuck one in another motor and need it out asap. so if you have any ideas, please do share. thank you
