Engine Brand VS Thread
buddyochoa
Not Senior Yet
Thorn Hill, TN
Honda, Briggs and Stratton, Kohler, Tecumseh(not around but the engines still are).
Which engine has better, reliability, cost, efficiency, ect?
Which are parts easier to obtain for? What about aftermarket, performance parts?
And it isn't nearly limited to these brands, there are plenty of others out there.
B man
Tecumseh FTW!
Oliver springs,Tn
Honda by far in my opinion is the best all around motor. Briggs will go the longest without maintenance. and i only saw my first Kohler today. 22.5hp twin. seemed to be a slow starter,but once it warmed up it ran nice. Tecumsehs are great,but being as no one ever takes care of them they get a bad rep.
r97
Measure twice cut once
Massachusetts, USA
Robin Subaru would be my top pick, Honda would be a close second even though it does have more modifications available if you are into that. A lot of Kholer's new engines seem to be rip-offs of Honda, but they look just as solidly built as the old ones. Briggs and Tecs are extremely common, lots of parts and pretty cheap, but many of their designs aren't made to last. That said they still have plenty of excellent engines to choose from.
Clones fit in too, I would say your average clone would be better than some of the cheap briggs and tec engines. These engines are very inexpensive and many people are very satisfied with them, but I would still rather save up a bit longer and get a really good quality piece. The lawn boy dura-force and victa engines also seem to be pretty good, although I have never used one.
fowler
Bullsbrook West Aus
Really everyone is going to pick a brand by there experiences and the climate they live in
In my experience Honda is the only one that can withstand the heat and dust
Kohler does good in the 34hp range but they have issues with the guards that trap dry material in and around the engine causing overheating and in extreme cases fire
Briggs doesn't have the build quality externally or internally
But to be fair we have only played with 04s forward
r97
Massachusetts, USA
Correct me if i'm wrong, but it looks like Subaru Engines and Subaru Automotive is pretty much like Honda Engines/Automotive.
Subaru Automotive and Robin Subaru Industrial Power Products are both owned by Fuji Heavy industries. I bet most of you didn't know that Fuji Heavy Industries also produces some engines for Polaris, more reading here, http://en.wikipedia.org/wiki/Fuji_Heavy_Industries#Divisions
I believe that the only similarities between the automotive and industrial engines is simply that they share a common name (In the U.S) and that they are owned by the same parent company. I have no clue what Honda Automotive and Honda Industrial engines share, but I would bet they are more closely related, along with Honda motorcycles, jets, marine power, etc.
buddyochoa
Not Senior Yet
Thorn Hill, TN
I had a early-mid 90's 18hp in an old Dynamark 5 speed lawn tractor with like 245/75R15's that happened to have the same bolt pattern as the rear wheels. The bigger size let it go like 25-30mph(closest estimate). I wish I still had it, I ran that motor full throttle for hours at a time, with no governor and it never quit.
buddyochoa
Not Senior Yet
Thorn Hill, TN
A little offtopic for this thread but here she is. No exhaust, no governor and large tires lol
:iagree:
Here's something to think about: All clone engines are base on something (hence the term "clone"). In 99% of cases, it's the Honda: there must be a good reason for that...
fowler
Bullsbrook West Aus
Yes they take a comon design and successful idea
Like Honda's GX range
And copy them almost exactly
They change some things to get around the legal issues
They then do all this for far cheaper than Honda
FatCat
2 stroke Addict!
Ottawa, IL
If these chinese "clone" engines are anything like a Chinese four wheeler they are junk. Absolute trash. I've never used one, never will. You can buy a good used name brand engine for the same or less than a new "clone". It's also wrong to call them a clone. In every use of the word clone it means identical. These engines aren't identical. Even if they look the same. Put a Honda and a clone side by side. The clone engine will be a boat anchor long before the Honda. At the end of the day you get what you pay for. Your paying for years of skill and engineering. Your "clones" are probably paying sweatshop labor to an 8yo Chinese kid.
exenos
Project Nut
Key words " never used one" Don't dis clones untill you have used then. For a $100 they're great. Mine is still going strong after years of constant abuse, all while running at 6k rpm. Most clones are almost exact replicas of gx200's, right down to part compatibility. The only difference with clones is the bore size, with the exception of the predator. I believe that they changed the stroke with that one.You are getting the years of r & d from Honda because they are essentially honda's, just made with cheap Labour.
clone
2. a person or thing that duplicates, imitates, or closely resembles another in appearance, function, performance, or style: All the fashion models seemed to be clones of one another
http://dictionary.reference.com/browse/clone?s=t
buddyochoa
Not Senior Yet
Thorn Hill, TN
Even if it is made with cheap parts, in the case of it dying, couldn't a Honda overhaul kit be used? Or are they not quite that compatible parts wise?
