clutch..
Russ2251
AZUSA:Powered by LAWN-BOY
There are 2 possible clutch mounting types:
Outboard mount, meaning clutch sprocket can only be mounted facing away from engine block. This type is secured to pto with a single bolt (typically 5/16x24) and washer via internal threads (usually has built in key).
The other type will mount inboard or outboard (sprocket toward or away from block) and uses set screws to hold it onto shaft.
I prefer the inboard/outboard type as I sometimes swap engines from mini bike to kart.
Kart is mounted outboard. Mini bike is mounted inboard. They are also movable (slightly) in or out for chain alignment.
bda28590
Still Working On It!!!
North Carolina
i got the same engine i just put a 3/4 clutch on it key comes built inside of it just had to get a bolt and washer for the out side works fine other then working on the gear ratio clutch i got around 20 dollars so they are not much
randomb0b123
hey russ2251 im looking for one of those clutches you are talking about that can be mounted inboard and outboard, where do you get yours? I need a 1 inch #41 chain
ZnsaneRyder
Crazy Guy on a Bicycle
FL
Where did you find a $20 clutch?
