Difference between 5.5hp & 6.5hp
Yes, I know, the difference is 1hp or 1.2Nm but, is it noticable?
I've been looking for an engine for my next project & I've found 2 places that sell the one I'm looking for. However, both sellers are out of stock of the 6.5 & have suggested the 5.5: Is there a noticable difference in performance between these two?
Now, before you say "go somewhere else", let me point out, there is nowhere else. Unlike you lucky buggers, over here, we can't just go to the nearest harbor freight & pick one up, they're a bit harder to find than that
souperman000
Westlake Village, CA
I would say it mostly depends on the gearing you use. Either way the more horsepower will get you up to top speed just that little bit quicker than the 5.5.
Depending on what your next project is/will be used for, I doubt the differance will be too noticable.
Mcbreja
Arlington, TX
I had a 5.5 on the dingo I had, and I had no problems with it. My nephews rode on it with no problems and they're heavier than me. I haven't used a 6.5 for kart purposes, so take that for what you will.
Don't you have a 6.5 on your daughter's kart? Would it be a major hassle to put the 5.5 on hers and use the 6.5 on your new project?
Devious- I LIKE it! Sounds like something I'd do!!!:devil2:
Fab- Can you not just wait until they restock?
No, it's only a 3hp
Probably but, they've both been on back order for about two months & I would prefer to "size up" the engine before I start building the frame.
I also have a few big expenses before I even think about it; I have to get a new cable run to power my new compressor (good thing my nephew's a sparky) & my power bill just came in, $850.
Thanks for the input guys
Not to mention I have to finish fallenleopards hubs, my scooter & about 4 other projects I have going ATM :roflol:
Blazkowiez
Kart Aficionado
Houston, Texas
What sort of engine is this? Typically the difference in 5.5-6.5hp is very slim on small engines. Carb, head, exhaust is usually the extent. If you plan to run a straight pipe, aftermarket intake, port the carb, and shave the head you'll be in the same boat in the end. Don't always listen to the hype.
Not really, you wouldnt notice it. and if your worried just add a straight pipe.
True, I could do all that which may bring it up to 6.5hp but, if I do that to a 6.5hp I end up with close to 8hp :devil2:
As I said, I have a bit on my plate ATM so I'll wait & see what's happening when I do have the time & money; there's lots I can do in the meantime
Blazkowiez
Kart Aficionado
Houston, Texas
As an example... Tecumseh 5.5-6.5hp engines 196cc use nearly identical parts aside from the head. Racing enthusiasts even seek these 101 coded heads for higher compression once they've jetted the carbs and fixed intake/exhaust.
Don't always think in terms of hyping an engine from 5.5 and 6.5hp differently.
You may end up with the same result.
Power here is also ridiculously expensive. They have been hiking the price 23% for the last 3 years to pay for new coal fired power stations being build. There was a huge lack of forethought by our power company in previous years, and now we are paying for it.
fowler
Bullsbrook West Aus
not sure if u guys have it over there but i have a large shop called australian air tools (really creative name)
they are the distributors of black cat air
i noticed the other day they have started selling the preditor clones only place iv seen along with honda and some yamaha engine
might be an option if u have such a place
also do u guys do road side pick up or verge collection
i always see old lawnmowers and other garden gear on side of the road
thinking it would be good to start a side income if i had the time
thats a hard power bill
mines only $150
but i guess u have a family where as i live with 2 uni students
stupid carbon tax, the power companys were doing a good enough job raiseing the price them selves with out the red head ***** helping out
who knows how she stayed in parliment so long
then again abbot is only just a better option
bring jonny out of retierment i say
Same here: We've had a little over 30% increase over the last two years
It's easy when you have the power brokers backing you... but, I still can't work out why
