PVC or CPVC Roll cage
michael prather
Hi, I was woundering if it is safe to use pvc or cpvc pipe for a roll cage. I was thinking about putting it on a murray explorer and my idea is to get some 1" pipe and with a table saw cut a line down it so it is in a "c" shape and driving it into some 1 1/4" pipe. then I would heat diffrent points of th pipe and bend it to shape. I would also add plenty of reinforcement to it. I wanted to know if this would be strong enough to handle a roll. The attached picture is the general shape I like but I would have more support added and it would be on a murray explorer.
Thank you for your time!
r97
Measure twice cut once
Massachusetts, USA
PVC pipe for a roll cage is a very bad idea, I'm sorry but the pipe will just bend and then shatter into very sharp pieces. The roll cage pictured is made from solid steel tubing.
r_chez_08
Should be in the shop...
Cornwall, UK
I can see your idea. However, PVC can shatter easily. Most plastics would not be strong enough with the same dimensions as a 'standard' steel pipe which is used for a roll cage.
Swabbster
use 1 and 1/4 or 1 and 1/2, steel pipe, 1/8 thick, for a roll cage you want to to be strong it could mean life or death,
Every roll cage I have ever seen is made of steel. Even nascars, dragsters, etc, worth in excess of half a mil still use steel rollcages
Mr.Tan
York, PA
it should be common sense that using that for a rollcage would NOT be safe... Steel ONLY!! you don't want to kill yourself
Mcbreja
Arlington, TX
Then you will add an extra hundred pounds to your cart before it snaps and punches through your skull.
Besides, do you know how bad cement dust in a cut burns? :roflol:
Yup- all you'd have in a crash is PVC shards, and chunks of concrete and cement dust. I know- Let's build a cage out of steel tubing! Wacky, I know- but stay with me!
klicky96
Sandusky, Ohio
You could go the cheaper, less cooler looking way and build a cage from 1-1/2" angle. Yes, the angle will hold, and around my town, angle is a lot cheaper than steel tubing.
deloreanaka8
Atm just gathering ideas
Lisbon (Portugal)
For a real solid and safe rollcage you need to use chromium molybdenum steel tubbing.
Pvc for a rollcage, only when the rider is a action man or a ken... ;)
Btw, ML-TOYS, where did you get those gorish pics from? :D
