opposed twin 18.5hp
nissinator
kansas
ok so i was riding around outside and out of no where i lost all power turns out my #2 piston wasnt firing so i pulled off the head and turns out the exhaust valve is stuck:furious2: but i can hit it back into place and turn the crank and it will open just fine but it wont close???? spring looks fine and i was thinking maybe the cam shaft is broke but it still pushed the valve open soooo any ideas? much help appreciated
Russ2251
AZUSA:Powered by LAWN-BOY
Could be bent or just coked up.
If bent, replacement will be necessary. Guide will most likely be messed up as well.
If coked up, a simple remove and clean (stem and guide) is all that is needed.
Check springs.
nissinator
kansas
its not bent so ill try and remove it and clean it but its a pain to do without a spring compressor lol
nissinator
kansas
well it moves very smooth but its the little rod that pushes open the valve but it doesnt close any reason the rod is getting jammed...i really dont want to tear into this engine
You mean the push rod: it may be bent or skewed. Looks like you're gonna have to pull the engine down somewhat; the only way to get them out is remove the cam
