Anyone know?
crazycart
RedNek Engineering
MINNESOTA
Water cooling allows for tighter tolerances, making much more power. EX. A air cooled 250r makes around 25-30 hp while a Water cooled R makes upper 40's. The air R's piston is 70mm and the water cooled R's is 67.5mm(IIRC). Watercooling is alot better in many ways.
crazycart
RedNek Engineering
MINNESOTA
Also, dont get me wrong, i love my air cooled 250r, its a freakin beast for what it is, but watercooling is gunna make you more HP which really matters!
crazycart
RedNek Engineering
MINNESOTA
Its all opinion i guess, Power does matter, alot in fact. For me, Power is the essence of Fun.
modelengineer
Lord of the noise
Sydney, Australia
I'm choosing to go watercooled on my off-road kart because I don't like the idea of having the engine overheat because I leave it running while stationary, for some reason.
I am going to replace the bike radiator with a small car one and a fan to make sure it NEVER overheats. Believe me, after spending all that money on an engine you can spend a little bit extra to stop it self destructing.
This will probably be on an SV-650 or KLR-650
The Dude2200
Massachusetts
whats the engine off of?
Kenny_McCormic
Kartless....
Michigan Troll
Not every engine is made for fun. Funmobiles should be powerful, a completely trustable SHTF vehicle needs to be able to run after sitting 10 years in the dead of winter. water cooling in that situation=cant help anything. Everything has its purpose.
crazycart
RedNek Engineering
MINNESOTA
Well there is the best of both, my R, is a 1981. Was on its ORIGINAL piston. A 2 stroke after years of abuse and high RPM.
modelengineer
Lord of the noise
Sydney, Australia
The engine will probably be from a Suzuki SV-650 road bike, a KLR-650 bike or, if I can find one cheap, a CBR600RR. MMMM, 120hp!
modelengineer
Lord of the noise
Sydney, Australia
No engine overheats in this scenario unless something is wrong with it.
Summer in outback Australia. 40 degree C days with no wind to speak of. Leave an air cooled motorbike engine running stationary in that sun and there's a pretty good chance it will overheat.
Water cooled bike engine which has a car radiator (much bigger than standard) and a large fan has a better chance of staying cool.
Also in a buggy you are often revving the engine a lot and not moving very quickly (sliding in a corner) so that just makes the situation worse.
