Something quite abit different
BillyBob128
England! :)
I was on vacation in Florida the other week and have taken a liking to the Disney Transport buses.
Does anyone know if you would be able to create a go kart bus?
Also I have a spare Briggs and Stratton 10hp engine, would this be of any use?
Nodroz
Belgium (Europe)
A gokart bus... the idea sounds cool - driving through your neighbourhood with the neighbourhood on your gokart, LOL.
How big are you seeing this bus? 4 - 5 people?
BillyBob128
England! :)
I was thinking along the lines of a 1/3rd scale one so could take 4 people.
On this drawing I have also marked roughly the center of gravity of the bus with people on it:
Nodroz
Belgium (Europe)
Lol, looks cool.
I doubt 10hp will be strong enough to pull a heavy gokart + 4 people, unless you gear it very low - something like 15:1.
BillyBob128
England! :)
It wouldn't be the most adgile thing in the world, lol
I'll be happy if I got 20mph out of it because the fullsized are limited to 60mph
Nodroz
Belgium (Europe)
Would I be ok using 14 inch wheels?
That would give you even more torque. Be sure they can handle all the load though.
If you still want to reach 20MPH with 14" wheels, you'll need a ratio of 7.5:1, which is quite high if you're travelling 4 people, or will he be okay?
BillyBob128
England! :)
Would used scaffolding tube be ok?
Its 48mm diameter and 4mm wall thickness.
Downside the stuff is 1.34kg a foot and the frame needs about 30ft of the stuff... So that is already up to 40kg
machinist@large
West Michigan, 49331
Would something along the lines of this be alright for the chassis?
Consider framing it up the sides; basically a space frame with the top completely open for the driver and passengers. That way you can use lighter gauge material for the main frame' yet be alot stronger overall.
By lighter matl., I'm talking about the same cross section, only thinner wall. I'd sketch it for you, but my computer and scanner are at war this week.:ack2:
machinist@large
Thats a good idea :) roughly what wall thickness would that be?
:toetap05: Hmmmm. 48mm is just under 2", and 4mm is basically .16" (thick) i.e. 'little under 3/16" (.187"). I don't think you are going to get away much lighter than that for the main frame; especailly seeing how long you would like to make it. Lets look at your first quick sketch; looking across it parralle to your shoes, it's a flat piece of paper: bends really easilly. If you fold the sides and ends up to form an open topped box, its a lot more ridgid.
I won't lie; I've never built something like this. That's why I'm going to wait for the others on this forum to weigh in; there's a lot of knowlege on this site.
48mm round tube will work but, for something like this, square tube is more versatile (just saying).
A 10hp engine has many uses but, this isn't one of them. By the time it's finished, this thing will weigh 150+kg, then add 4 - 5 bodies @ an average 75kg each, that's somewhere around 500kg, waaay too much for a little 10hp no matter how it's geared.
Don't get me wrong, this is a great concept, it just needs a bit of rethinking.
