Hello, A few Questions
GreyW00lf
Nova Scotia, Canada
Hello,
I live in Canada and I have Searched the Forums for info But everything is Confusing.
I am planing on Doing this to give myself something to do as a hobby.
I have a few Questions about what materials, tools, Welder are basically used and I mean basic tools you can get away with being used to make a Custom Go-kart / Buggy
I was Planning on buying a Miter/Compound Saw, a metal Cutting Blade and Using Square Tubing to began with until I get some more Experience at welding.
Welder i was Thinking of Buying
That welder will be fine but, it seems a bit expensive; I've seen the same for half the price. Other basic tools include a drill, drill bits, spanners, sockets, screwdrivers, the usual things. Have a look at this thread;
http://www.diygokarts.com/vb/showthread.php?t=9580
When selecting materials, remember that large, thin wall material is better than small, thick wall material: ie: 2" tube with a 1/8" wall is better than 1.5" tube with 3/16" wall; the 2" is just as strong (if not stronger) & is a fraction of the weight.
Now, I'm not saying go out & buy 100' of 2" tube, that's just an example. the size you select depends on the size of your project; most likely, you will only need 1" 16guage tube. Again, that's for a small kart; a larger project calls for larger material.
Give us a bit more detail about what you have i mind & we'll help any way we can :)
TheWingnut
Del Rio, TX
Yes, a wire welder/ mig welder would do great, but why own a welder if your only going to use it during certain points of your projects? I am simply renting out a welder for abut 30 bucks for the whole day. And also i would get a grinder, an electric hack saw or metal cutter, a vice, some clamps, a script, some soapstone, and an angle measurer (I am blanking on what its called sorry).
This is everything i used when building my kart. And also here are the website where i got all of my gears, seat, axel, etc.
http://www.mfgsupply.com/gomini.html
http://www.jackssmallengines.com/go_kart_parts.cfm
http://www.gokartsupply.com/
http://www.bmikarts.com/gokarts-minibikes-chopper-parts.shtml
(BMI karts is where i got all most of my things)
Edit: I forgot to mention the engine. The engine i got is from Home Depot website im pretty sure, if not then there are many other places, just look it up on google haha.
Hope this helps
GreyW00lf
Nova Scotia, Canada
Hey,
Thanks for getting back to me so Quickly Gentlemen
The only reason I'm Buying a welder is because it's Cheaper and Better for me to buy one then to rent one in the long run and I Would much rather own my own Tools. If I were to rent a Welder it would cost me around $80 Dollars a Day plus you have to pay a deposit and that is more then $200+
I'm going to use your advice and grab the 2" Tubing.
As to what I am Gonna make...
I am Planning to make a 2 Seat Buggy with All Four tires on Independent Suspension. with
2 3x4 Square Tubing From Front to back For the two main Chassis Frame/Rails with the 2" Round tubing Coming off it.
There will Also be a Small Dump Box For hauling Stuff on the back above the Engine and a Small Car's Fuel Tank For the Fuel Tank.
The Engine is Going to Sit a little in front and lower then the Rear Axle.
Speaking of the Rear axle I was thinking of putting some sort of Lawnmower's Differential back there with a Chain running to a jack-shaft then from the jack-shaft to the engine to Gear down the Speed and get more Truque. (truque is misspelled I know)
I am putting the Engine as Low As possible as well because of the Fuel tank that will be used above it.
(I would Draw the idea if I could, But what I have in my brain gets lost in translation to my hands as I Draw it)
from the Differentual to the tires there are 2 Universal Joints (Axle) per Side of Shaft (see picture)
I'm going to use as Much Four wheeler parts that I can get away with.
(A-Arms, Spindles, Suspension, Engine)
As I suspect that this Buggy will be heavy with myself or Anyone else in it so I am Planning on at least having a 600cc Four Wheeler Engine (ATV) so I can have reverse as well.
Tires Will be Minimum of 15 Inch ATV Tires in the Front and have a bit taller rear wheels that are also a bit wider.
Note:
I am still Price shopping around for most of everything needed including a Welder.
(welders where I live are not cheap due to the Local Economy and Supply and demand)
Also When I posted the Welder Link, I just grabbed it for the Welder Information and you guy's opinions.
Welcome to the forum. I look forward to your build.
Have you decided on what sort of gearing you might be using? I would agree with you about using a jackshaft and gearing lower if you are going to be towing things around. It is also a 2 seater, so there will be some weight on it at times. I would also suggest using a torque converter as opposed to a centrifugal clutch
GreyW00lf
Nova Scotia, Canada
@Landuse
well if i'm going to use a Four wheeler engine it has a Clutch and gears Built into the engine Block
But right now i'm still in the Desiging and Buying Phase..
Hey,
True, but $600 for a gasless welder is way too much; look around. Harbor freight have some ok welders for half the price
Note:
A beast that big is gonna need 2" tube. Just watch the weight; you don't want the engine to struggle to move it
Good luck, have fun & keep us posted
GreyW00lf
Nova Scotia, Canada
You want to use mower trans with 600cc engine?
I didn't think that part through all the way all I know is that I am somehow gonna want to put a differential in there.
I just might find instead a 600 cc engine that is shaft driven as those usually have 4x4 capacity and a differential on both shafts leading to the Rear and Front from the engine
