Tecumseh Enduro Carb
Stephen115
I recently acquired a Tecumseh Enduro off-road kart from my step dad. (one of those, you can have it if you fix it things) I sprayed some starter fluid in the carb and it fires right up. then dies. put gas in her and the gas just falls right through the bowl. so I got a new bowl, well turns out there isn't a needle in it, so i bought a carb rebuild kit. I just installed the needle and new bowl, now the gas flows right out the carb, I mean just flows out like a waterfall out the intake side. why is it doing this and how do I fix it?
i'll post picks later
thanks
SJ
It would seem the float valve is not seating correctly. Check float adjustment against spec, verify correct mounting for needle, and ensure that the seat is undamaged and seated properly.
Stephen115
I don't have a seat tool, whats another way to remove/install ?
slideways
Take the bowl off and take pics of the carb for us. Try taking the bowl off with fuel in and gently lifting the float up/closed and see if you can make the fuel stop almost completely. If not something is out of whack with the seat.
Stephen115
ok, thanks
Stephen115
ok, I put gas in the tank and no gas was coming out of the carb this time. I turned it over and gave it some gas and it really wants to start but it won't. I pulled the bowl off like you said and when the float is all the way down gas pours out, with the float 3/4 up or higher no gas comes out. hope this helps you help me
thanks
SJ
Okay- that sounds positive- now-
Remove the spark plug. Pour a teaspoon(ish) of fuel right into the plug hole and stick the plug back in. Snug it up, connect the wire, and attempt to start the engine. What happens?
Stephen115
ok, i did what you said and it will run if you give it gas and then only run for a sec or two with throttle open. spark plug? also the bowl is leaking alittle around the seal. i don't know why but I don't see it effecting running. I also played with the a/f and it helped alittle but not enough.
here is the kart:
and here is the carb:
Disassemble, soak in carb cleaner, poke out passages with fine wire, blow with compressed air, hose off in WD40, etc. What you are describing are symptomatic of a gunked-up carb.
Did you take out, inspect, and clean the main jet?
Stephen115
I did not, where would it be on this carb?
When you remove the bowl nut (and the bowl), you will find the main jet in the center leg of the carb that the bowl nut threads into. You will need a flathead screwdriver to unscrew the jet (from underneath). The jet is a small brass fitting, easy to lose. Be careful.
Stephen115
thank you, how would you recommend cleaning the jet?
Stephen115
I did some research and my carb has the jet in the nut that holds the bowl on. it was clogged, i cleaned out the top of the jet but I couldn't get to the bottom where the two holes are, somethings in the way? put it all back together and it will idle for about 6-7 seconds then die and when I give it throttle i dies right after.
I'd have to see the nut. Is it adjustable? Either way, there should be a tube running straight up from the jet into the carb venturi, make sure it is clear. You can poke fine wire into all the holes. Be patient, if it's sat with stale gas in it for quite some time, it can be quite a deal to get it all cleaned out.
slideways
Also you are missing the link between the governor arm and the carb butterfly. It looks like a twisted staple. A true masterpiece of engineering.
Keep in mind you are dealing with a very difficult carburetor to begin with. Usually Tec's need to be warmed up for about 1-3 minutes before they will even begin to take throttle and rev up. You can try lightly pumping the primer when you rev it a tad and see if that helps.
Stephen115
Ok I got it running, its hard to keep it idling but atleast it runs. Can someone help me with the throttle set up on this kart? I've never delt with Tecumseh's before.
