GX160 Head size???
fresh101
Pembroke Pines, FL
Hello, can someone tell me what size head this GX160 has, 14cc or 18cc?
Block reads as seen in the picture:
Honda GX160-163cm3
QX2X or *(star)
GC02-6417458
THANKS IN ADVANCE
r_chez_08
Should be in the shop...
Cornwall, UK
Looks like my 14cc, not an 18cc shape at all.
Nice head, that is worth a bit because it looks brand new and genuine 14cc's are not made anymore IIRC.
Did that come with a thick .045 head gasket?
fresh101
Pembroke Pines, FL
It's just looks, the head is not new. I sand blasted the head real good, on every direction, ports, and fins. I did the same thing with all the parts, piston, rod, shaft, block, valve, throttle link and etc. About gasket, I am not sure, I discarded the gasket as I wanted to replace as much parts as I could, to new.
r_chez_08
Cornwall, UK
Wow, I want a bead blaster now! Tempted to get a little one, or make one!
Never mind about the gasket. Good luck with the build, should be fast!
What is happening with the rest of the gx160?
fresh101
Pembroke Pines, FL
Yes bead blast is a cool stuff to have, lucky I have one at work. Not doing anything to it, I will use the head of the gx160 for the z-208 block. I am working on getting the rod, crankshaft and cam for the z208, I believe they had said I can use the predator crank and rod and piston but don't know which rod to go with as predator had 2 options.
r_chez_08
Cornwall, UK
Nice. You could sell some of the 160 parts to fund your 208 build.
You can use the predator crank, piston and regular length rod in the z208 but you may have some pop up (the stroke is about .040 extra so .020 each way, if you are .020 in the hole you will have 0 pop up.)
Alternatively you could use a performance piston and the predator long rod with the predator crank.
Or go all the way and use an arc .125 billet stroker crank.
