6.5 hp Predator engine keeps back firing
Gokartguy04
Pickin junk is my thing
Colorado
Hello guys,
I am new to this and I have a question. I have a 6.5 hp predator engine from harbor freight it's about 6 to 8 months old. And ever since I've had it it has been back firing and half throttle and I can't seem to figure out why I changed the spark plug and made sure my gas was the quality it listed but it still back fires. So could you guys help me figure out why. Or tell me how to fix this issue thanks.
Br@ndoM@n
Dude with a gokart, a MIG
New Mexico (Not Dirty Poor Mexico, NO HABLA ESPANO
If ur backfiring ur getting unburned fuel egniting in exhaust. as seemefly said it sound like your mainjet. but why bother messing around withit when its under warranty and u can just exchange it and not worry about messing with the carb or them rejecting ur warranty if u mess with it then decide to return it.
U running a stock muffler or header? I have a header on mine and when she is at WOT and returns to idle she tends to pop and u can see flames out of it at night.
seemefly
back firing
these engines are working not for racing if harbor frieght see any alderations on the outside the engine thier new rules they will not accept the return. beware they are not stupid. you need a briggs raptor engine.
r_chez_08
Should be in the shop...
Cornwall, UK
What are you on about? Where did the OP say they are racing it? Using the warranty due to factory defects even if the engine is used for motorsport is perfectly legit providing the engine has not been tampered with, e.g. governor removal or aftermarket components.
Also, it is not just external modifications but internal modifications too. I have heard the HF insurance company dissasemble the motors checking for any alterations.
Hondas and clones may not be made for racing, but why should that stop people using them for this purpose? The clone class is one of the fastest growing karting class due to cheap power and the wide range of aftermarket parts available.
seemefly
what i am talking about
this reply was to u.s. viewers not to the uk people we have epa standards. harbor frieght give people alot trouble because of their misuse . if you need to race kart motor use and old brigg, kohler and techcusem motor they can better from alderation. you can not get more out of something that you have not pay for.
thank you,
from the UNITED STATES
r_chez_08
Cornwall, UK
Once again, where did the OP talk about racing it?
And why are the Briggs/ techumsehs etc better?
More bang for your buck with a clone.
We have clone racing in the UK too. And EPA regulated engines.
No harbour freight, but I do not have to be from the United States to go on the Internet...
Thank you,
From GREAT BRITAIN (wow that was immature of me..)
tundrabeagle3
Ca
I agree my clone predator 212 does the same thing when I let off from full throttle to idle. I have a 90 main jet, k&n style filter and header. If yours is stock and having this problem then I would return it for another.
I agree that predator 212 can be used for racing but requires more mods like stiffer springs. My slightly modified 5 hp has a lot more torque than my predator and hits higher rpms with stock springs the and was a lot easier and cheaper to modify. They are torquier because they have a heavier flywheel.
Thank you,
I'll be immature with you...:D
Thank you,
From SOUTH AFRICA
r_chez_08
Cornwall, UK
Useful to know, thanks.
I noticed when disassembling my 3hp flatty that the springs were stronger than the ones on my 6.5hp clone! The flywheel felt about the same weight too.
Blazkowiez
Kart Aficionado
Houston, Texas
Run sta-bil in your gas, the problem was caused by old gas messing up your carb. It'll happen in this one too if you don't fix that.
