Carburetor Adaptor - AGK
thleeet
CA
Do I have to cut my screws that come from the cylinder head to fit this adaptor?
https://www.affordablegokarts.com/images/manifold/DIY-Curved-Manifold-3.jpg
a picture that they show is a lot shorter than my screws..
:huh::huh::huh::huh::huh::huh:
r_chez_08
Should be in the shop...
Cornwall, UK
No you have a 4" stud. This will obviously not work with your carb adapter as stock.
The threads on the cylinder head side are only really long enough to thread into the cylinder head and not attach the adapter on to the head. In order to do a proper job, I suggest you either get some new shorter studs (6mm in diameter, STD. pitch) about 30mm long, or get some allen head bolts which appear to be what AGK use.
Or just use some normal 6mm bolts.
Whatever you use, make sure it is decent stuff, grade 8 or higher.
Crap fastners are a PITA and can strip or stretch. I have stripped and damaged a few of the stock studs on the clone motors.
thleeet
CA
how do you take the studs off?
spyder1968
New Bedford, MA
vicegrips !......or .....sometimes you can put 2 nuts on the threads and tighten them against eack other as tight as yoy dare. then put your wrench on the nut closest to the engine and turn counter clock wise. i just use good vicegrips, cause for me it is faster.
thleeet
CA
thanks man! helped a lot!
thleeet
CA
thanks for helping me!
