Tecumseh 6.5 motor, fix or replace
EHREYES
ok dont know if i got a deal on it or not but here in Nor cal , SF bayarea on craigslist i found a Yelf Dog go cart side by side 2 seater full roll cage for sale for $400 non running.. said bad carb..i seen other go carts for sale but non had full suspention like this one.. so i bought it for $400 .. they had it listed for $600 at 1st..i fixed the carb by replacing the floater... now that my sons been riding it he wants it faster..now he broke the pull start.. been thinking of just pulling the motor a getting a bigger one.. but my question to you guys is this worth keeping..or fixing..can i upgrade this motor..or should i dump a few hundred on a bigger one..thanks!
cumminsbayou4x4
fairhope alabama
id say throw awy the tecumsa they are crap go to harbor fright and get the 212cc predator or the 11hp or even the 13hp then get a 40 seris tork converter this set up is gonna cost you like 500 dollors tho but if you go with the 212cc it wont go any faster
r_chez_08
Should be in the shop...
Cornwall, UK
I would not replace the 6.5hp tech with a 7hp stock predator, or throw away the techumseh.
What is up with the techumseh recoil? Either keep the motor as a spare or sell it for a few $.
You could always remove the governor on the techumseh but I wouldn't reccomend many more revolutions.
How old is your son, how mechanically inclined are you and your son, what tools do you have, what clutch and sprocket sizes has the kart got, and have you got a pic?
Answer these questions and I will answer with my opinion of a suitable combo for the situation.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I wouldn't remove the governor on the tec at all. These engines are cheap since they use lower quality parts. A few months ago (around Feb/March) I tied a rope to the governor arm as some people try, and pulled it after I hit max rpm. Pulling it barely made me go any faster and made the engine whine. So I went up on the grass foeld, hit a small hole in the dirt, and the rod let go. Engine blocked cracked in 2 pieces. The entire cylinder seperated from the crankcase and had the head and gas tank in tact, being held with the blower housing. Tecs suck, and I will never buy one again. I've used my predator and hit 4,500 rpm w/ no load (I know that's stupid to do.) And the governor in tact.
EHREYES
im very mechanically incline.. as far as tools i got everything plus lil more besides heavy machine working tools ..like to bore cyclinders..i mostly build race motors for my Mopars.. my sons 9 years old.. im changing everything ..clutch, sproket all..currently have the cart on a jig i build to add about 6 inchs more to it. streched out the frt arms 3 inches to get more suspention travel..i would love to put reverse in it.. im really mod-ing this cart in hopes i can get it green stickered by the state of cali as a off hwy vehicle..there will be a secondary sproket on the drive axle that will turn an alternator with an internal regulator (one wire) so i can run lights and aux..but i1ist i need to know what i can run to power it all..something good,,powerful i can use in sand..i dont know NOTHING about these small motors,,so as much as i know about a big block 440 im kinda lost on these small ones.. thanks guys..any u cali folks need things fab up i can help you guys
B man
Tecumseh FTW!
Oliver springs,Tn
That dosent mean there crap. there actually ALOT better than those knock offs. Yours just wasnt taken care of.
Well the whine was probably early hint of the rod being bad.
B man
Tecumseh FTW!
Oliver springs,Tn
The tecumsehs are Actually great engines. They have WAY better power to weight ratios than the honda knock offs.
The main reason no one likes them and says there crap is there not taken care of. left to sit with fuel in them and the carbs gum up. The honda knock offs are made VERY cheaply. theres a reason there only 99$.
I would fix the tecumseh. unless its completely trashed.
cumminsbayou4x4
fairhope alabama
tecumsa are junk they dont last long sling rods and the carbs are junk its not cause gas sits in them its cause they are cheap made as for power if you want revese id find a cheap 4 wheeler and use the motor
B man
Tecumseh FTW!
Oliver springs,Tn
Dont last long? they'll last longer than any honda knock off.
And Yes if you let gas sit in your carb its gonna screw up. same thing will happen with ANY engine.
the only reason a rod would sling is because of poor operator maintenance and care. the rods are better than the honda knock offs.
And if they are SOOO bad then why did almost ALL of the karting companies and mini bikes have them?
There one of a very few engines made to take the off-road abuse and use of a go-kart or mini-bike.
And the only reason it happens to you is your own fault for bad maintenance.
EHREYES
what u think about these reverse gear boxes they sell?
Yeah... Whatever...:eek:ut:
Tecumseh didn't stay in business as long as they did buy building crap. Ultimately, they did go under but that was a financial thing. GM and Chrysler went down- is that 'cause everything they built is crap? The ONLY reason they are still in business is because of a HUGE cash injection from the government!
ANY and ALL issues you may have had with Tec boil down to maintenance. Period. 90% of all the OPE I've had over the years has been Tec powered. I've NEVER had a problem beyond normal age stuff, like the magneto.
Whoever is feeding you this crap is talking out their @$$!
EHREYES
can you cam these up..maybe go better piston, rod and bearings,, also i would really like to cam one up and do a duel carb set up,, like a tunnel ram.. i can custom make a intake my self,,
if so where can i find these parts.. any way of putting an electric starter on them?
B man
Tecumseh FTW!
Oliver springs,Tn
mods for these engines may be a pain due to the company going out of business making these modded parts less common. And the ones out there arent to cheap.
GoodWComputers
Aspiring Mow-Kart Owner
Oxford, Ohio
Figure out the exact model of your specific engine. A lot of riding lawn mowers that had Tecumseh engines had an electric start upgrade. I'm replacing the starter on my Tecumseh 10 hp right now.
