gy6 wont run
xamoman
i have a gy6 150 cc that wont run without a charged battery. earlyer i was able to use a car batteri to stort the engine and go driving. now the engine dies as soon as i disconect the battery. what could be the problem?
I'm not familiar with the electricals of a GY6, but-
If you told me your CAR was doing that, I would tell you that your alternator is shot so the coil is using the battery to feed the ignition system.
Anybody here know if the GY6 uses a coil, or magneto? If it's the coil, I think we have a winner.
xamoman
my engine has what they call a pickup coil. how can i test if mine is faulty. could the problem be somewhere else. i should probably mension that the problem accourd when i rebuilt the enging onto a different frame.
xamoman
i am kinda confused. the way it looks to me i have both magneto and coil.
Nodroz
Belgium (Europe)
Not sure if this has anything to do with your engine, but my Kohler K181 with electric start will shut down as soon as I disconnect the battery. The battery just makes the circuit closed so the engine can keep running. Also, my engine is charging my battery, so no problem there.
xamoman
i have tried to connect a flat battery to close the curcuit with out luck. but as i mentioned earlier i have been able to run without a battery once i have started.
Nodroz
Belgium (Europe)
Oh, I didn't read that carefully enough. As Toystory said, look for cables that are not connected or damaged and be sure the right cables are connected to the mass.
xamoman
i tried to connect things according to the diagram, but it didn`t work. i guess i need to get my hands on a multimeter and check all the components and leads.
why can`t things just work sometimes????
