New guy with some Q'
jeckel7234
Hey all,
I have 4 year old son and im planning on building a go kart for the 2 of us to have some fun on. I dont have a set plan for how i want to design the frame ill probably design something on autodesk inventor before i start but im planning on using one of the newer harbor freight engines the 6.5hp, and using the 13" wheels HF sells. Im somewhat experienced welding. Do you any of you have any expierience with these engines? So far what research ive done they seem to be pretty good exspecially for $100. Or any other advice you expierienced fellas have, As of right now im not planning on having much suspension to it.
Thanks again
First thing; can you post a link to the wheels you mentioned, just so we can tell if they'll be suitable.
Are you planning a two seater so you both ride at the same time? Do you plan for your son to drive it too?
jeckel7234
My personal opinion/experience with B&S is not very good, so im still kind of thinking of going with the HF version, and opinions?
Rochester, MN
Absolutely: stay with the engine from your cousin. Harbor Freight is a great place to start with an engine. In the end.... the engine is the easy part of the kart, so you might as well get an inexpensive one, and then put your main efforts into the makings of the kart. I have made 4 go karts over the years, and honestly, the best thing about go karts, is starting simple, and having your son learn throughout the years, how to fix it. Your tires look totally fine. What worked best for me was to find a small riding lawn mower frame in a junk yard, and start there. That way, you have your steering (hardest part IMO) all set up for you. Good luck and have fun!
Not exactly. If it's only a low speed kart with a dead axle, yes but, if you plan on a live axle or any speed (I'm talking even 10 - 15mph), you may have problems (I found out the hard way). Good source for wheels though :)
Those wheels should be fine for the front, but you will have to find some with a keyway for the rear.
jeckel7234
any recommendations for the rear wheel, i was planning on just a solid axle, but what ive been seeing and what im assuming with the weight it should run about 30mph ....... right?
As I said, riding mower or check out the suppliers in the link directory (bottom of main page)
I was planning on just a solid axle, but what ive been seeing and what im assuming with the weight it should run about 30mph ....... right?
That depends on a lot of factors: overall laden weight, power output, gear ratio... You may not want it to do 30mph for now, until the little fella gets used to it; the last thing you want to do is scare him off
I would agree with gearing the kart for less than 30mph. The main factor in your kart speed is your gearing. (Tyre size is also important. The larger the tyres, the lower you will have to gear). Gearing all depends on the tooth count on the clutch sprocket and the axle sprocket. I would suggest that you gear your kart low (a higher number, eg 8:1), as opposed to gearing higher (a low number, eg 4:1).
This will give you more torque, but sacrifice a bit on speed. There is always a trade off between speed and torque when it comes to gearing. If you gear to high you will fry your clutch. If you gear too low, you won't have any speed at all but you will be able to pull stumps out the ground.
To calculate your gear ratio (if you don't have a jackshaft) you divide the tooth count on your axle sprocket by the tooth count on your clutch sprocket. This will give you your gear ratio. 6:1 is a general ratio that most people aim for, but in your case I would gear lower because of your son. You can always change the gearing at a later stage if you want some more speed.
If you do decide to use a jackshaft, the ratio is calculated as follows:
(JS in/clutch)*(axle/JS out) = ?:1
You can also play around with the speed calculator on the site HERE. Have a look at THIS STICKY as well. It has all the info you might need.
Oh....welcome to the forum
spyder1968
New Bedford, MA
just a little note about those tires. if those are the type for a dolly or hand truck , i would highly recommend changing the wheel bearings. hand truck bearings usually do not hold up on a kart in my experience.
jeckel7234
I picked up the motor from my cousin yesterday, he told me it had a gear reduction unit but neither of us assumed it had such a slow rotation. So I called around and apparently its a big deal to remove that and replace the crankshaft? So it looks like im going to go back and get the HF motor.
and lastly thanks for all the great info
Wait up; I cant see it being any more than 6:1 which is around the ratio you need. The reduction box negates the need for the jackshaft mentioned earlier. This is an advantage, not a disadvantage.
The only disadvantage here is not knowing what the reduction ratio is. There are a lot more advantages
Does it have a built in clutch?
jeckel7234
im sorry but i dont really understand what your asking as far as the clutch, the centrifugal clutch that i add on the shaft? And how is this a advantage. I know he initially bought it to use as a log splitter, please fill me in.
Some reduction boxes have a centrifugal clutch built into them: with the engine not running is the output shaft free, ie: can you turn it, or at idle can you hold onto it?
In the last few posts we have been discussing the need for a jackshaft to reduce your gearing. With a reduction box already on the engine, you won't need a jackshaft because your output shaft is already geared down (following so far?)
Let's say, for arguments sake, you want a 6:1 gear ratio.
Without the reduction box: 12t clutch, 72t axle (72 / 12 = 6)
with 2:1 reduction: 12t clutch, 36t axle (36 / 12 = 3 x 2 = 6)
with 3:1 reduction: 12t clutch, 24t axle (24 / 12 = 2 x 3 = 6)
with 4:1 reduction: 12t clutch, 18t axle (18 / 12 = 1.5 x 4 = 6)
with 6:1 reduction: 12t clutch, 12t axle (1:1 x 6:1)
So, let's say you have a 2:1 reduction, if you use a 12t clutch & 72t axle sprocket, you will end up with a final ratio of 12:1
Fabroman first off thanks it sounds like youve done this once or twice. I cant spin the shaft by hand when the engine is off. I get were the gearing comes into play with speed and torque but im not understanding why that low of a gearing would be ideal for a go kart.
This is the exact motor with gear box (6:1)
https://www.northerntool.com/shop/tools/product_200359772_200359772
You can spin the shaft, but is it spinning freely or is it turning the engine? If the reduction box is already fitted with a clutch, that will lower your costs as you won't need to buy one.
When it comes to gearing a go kart, you need to find a good balance between acceleration power & top speed.
Gearing too high (low ratio numbers) gives you a high top speed, but you won't reach it because acceleration will be lousy & you'll burn out your clutch in the process.
Gearing too low (high ratio numbers) gives you great acceleration but you'll have a low top speed.
In most cases, the magic number is 6:1. In your case, that number should be higher (about 9:1) as you don't want a high top speed.
Now, with an engine fitted with a reduction box, the output shaft is already spinning slower than the engine, thus requiring a smaller axle sprocket to achieve the same ratio (see table above). If your engine has a 6:1 reduction box & you use a 12 tooth clutch, an 18tooth axle sprocket will give you a drive ratio of 9:1 (18 / 12 = 1.5 x 6 = 9)
jeckel7234
ahhhh i see what you did there. Ill double check tomorrow but im assuming that it turns the engine since i couldnt spin it easily.
