spyder1968
As far as the brakes go, it looks as though you have a mechanical caliper. From the pic it seems as though the wear pattern on the rotor is not right on the outside edge. If the pads are okay, and the caliper is working correctly, it seems you could increase your braking power by mounting the caliper slightly further forward so that the wear surface on the rotor is right to the outside edge, this will give the caliper sightly more "leverage" on the rotor. It would cost you nothing, but a little time, to find out. BTW, good job on the jackshaft!
