New project pics, need some advise
blackthunder
Here are pics of a go kart rolling frame, what you see in the pics is everything I have. Looks like someone grew out of this and scavenged parts. Anyway, I would like to fix it up for my 4 year old to learn on since it is small and light...
I have a 49cc Cag pocket rocket that has a good engine/centrifugal clutch that I would like to made us a jackshaft to gear down to only top out at 10mph or so...
1st problem I have is I don't have the gear that drove the rear wheel. Anyone have ideas about what brand/type kart this was so I can look for a replacement.
Or is this a worth while venture?
Thanks,
Finding a rear sprocket they'll bolt right on is probably going to be tough, but you could order one of the sprocket blanks here at this site: http://www.gokartgalaxy.com/sprocket_blanks.htm
And then drill/file/die-grind its center hole to kind of an oval shape to fit and lock on the inside end of your left stub axle, then secured with a lock nut. Those sprocket blanks have a 1" center hole, so you'd need to measure your stub axles diamiter to see if those sprockets could be modded to fit or not.
At first glance, that may or may not work. The overall size of the mounting area looks to be around 1"... but I could be wrong. Measure the mount (as seen in pic 3) & report back.
@ anderkart: I would assume those sprockets are hardened so welding would be a problem...
blackthunder
I measured that on pic 3 and the round part is 5/8 inch and the diameter of the slotted part is 1/2 inch... don't know how to word it correctly.
Then you might be able to modify one of the 3/8" or 5/8" Steel Sprocket Hubs you'll find listed
at this link:--> http://www.gokartgalaxy.com/uni-hubs_&_vari-hubs.htm
(they're listed about three quarters of the way down that page, part #'s 2037 or 2038)
Then simply buy one of their sprockets made to bolt onto that hub. That site lists they're sprockets with the P5256 bolt pattern on this page:--> http://www.gokartgalaxy.com/shifter_kart_&_quarter_midget_sprockets_for_.htm
I'd never suggest welding any sprocket directly to any type of axle. I'd be kinda tough to take it apart to clean/lube the bearings or replace the sprocket. Although welding a sprocket to a separate hub might be fine.
No no no: I was thinking if the overall size of the shaft was 1" he could weld in the flats, then with a bit of grinding & filing it would work.
I was also thinking along the lines of the latter: find/make a plate that fits the shaft then bolt on a standard sprocket.
That means the overall shaft diameter is 5/8" with 1/2" flats.
How are your fabricating skills? Do you know someone with a milling machine?
A mounting plate/hub would not be hard to make if you know what you're doing.
The other alternative is to hunt around in scrap/junk yards until you find something that will fit :worried2:
blackthunder
If I were just put in a light duty live axle in, what would be a good kit for this type of kart?
spyder1968
New Bedford, MA
a live axle will USUALLY make the cart tend to "push" more in the corners. ( versus the same kart with a dead axle) in other words....it will probably greatly increase the turning radius. this however is not written in stone.
