2 stroke engine rebuild.
SCK
Custom builder
Not for you to know!
Hello every body I have a 2 stroke engine like this one http://www.ebay.com/itm/47cc-49cc-2-STROKE-ENGINE-MOTOR-MINI-QUAD-ROCKET-POCKET-BIKE-BICYCLE?item=150748784257&cmd=ViewItem&_trksid=p5197.m185&_trkparms=algo%3DSIC.NPJS%26itu%3DI%252BUA%26otn%3D12%26pmod%3D260760514727%26po%3DLLIW%26ps%3D63%26clkid%3D9049572008789254091 I need to get a new fly for my and I want to get a new carb and get a better spark plug and a big bore kit too.Also want to get some other stuff but first need to get some money. Then when I'm done with that I want to build a mini dirt bike or maybe a small pit bike or something along those lines. To put the 2 storke engine in.:D
tundrabeagle3
Ca
1.7 kw is only about 2.2 hp which is pretty weak. if i were u i would get a 110 cc pit bike already built with a 4 speed transmission(pretty cheap on Craigslist) which have around 7hp, alot more torque, and a more useable powerband and a top speed of around 50 mph. or just the motor with trans like a 125 cc lifan. with 2.2 hp two stroke engine i would expect a low top speed with little torque .
:iagree: That motor would only be good for a pocket rocket. You could mount it onto a bicycle or scooter for a bit of fun.
If you want a mini dirtbike/pit bike, buy one already running
SCK
Custom builder
Well I'm not doing it any more cause when I was taking the engine apart I broke part of the clutch and I'm not going to pay money to replace it cause it just cheap china junk and don't want put more money in to it. But I still want to build the bike and just find other engine to put in to it. Like you said 125cc engine or may be 110cc engine depends on how much money I have to spend on a engine.
SCK
Custom builder
Buying a mini dirtbike or pitbike is not as fun as beanble to say yep I built that! Well I'm not using the small 2 stroke china junk engine any more cause its just junk. I might try to find a 110cc engine or may be 125cc engine.
Nodroz
Belgium (Europe)
"Chinese Junk"
On what ground do you decide to say that?
I have had the same engine twice. Once on a very lightweight gokart, it worked fine and it got really some nice torque. Remember it is a 2 stroke.
Some days ago, I got a pocket bike in my hands. The engine wasn't working. I cleaned the carb, and repaired the fuel lines. Today, the engine is running perfectly. It starts pretty fast and I can go around 40-45KPH.
This engine is a really good for things like a pocket bike of very small lightweight bikes. Ofcourse it's not good for a gokart. It's cheap and works. What else do you need? :D
However, don't expect it is the same as a $300 engine.
SCK
Custom builder
"Chinese Junk"
Yeah I have read many things were people use these engines and stuff and thier very fast but I think I got a bad engine or something cause I had this engine on a different bike and it wasn't very fast and was a pain to start and yes carb was clean and stuff like that.
matman55
I dont have a camera!!
Mims FL
my two stroke ryobi 725r is a super hard start,and its not even a bad engine.it still bogs down but i fixed that by takin off the epa colored mixture screw cap things.
