Governed Idle- FYI
The governor is a seriously misunderstood engine control system. For the greater good, here's a little FYI, an experience I just had. Might benefit someone in the future.
Where were we? Ahh, yes- the governor. Contrary to popular (mis)belief, the governor does much more than limit engine speed to 3600 RPM. Wonder why it's not called a "rev limiter"? 'Cause there's more.
The governor's purpose in life is not so much to limit RPM, but SET it. What's the difference, you ask? (I swear I just heard one of you ask that!) The difference is this. SETTING an RPM means KEEPING it throughout the workload. Let's use a lawnmower for example. You start the engine on your walkway and run the throttle up to max. The governor sets the engine to 3600 RPM, and there is no load (not cutting grass). As you move into the grass, the engine starts encountering a load. The governor allows a throttle increase to bring the revs back up to 3600. Cutting away, you encounter a thick patch over the septic tank. As the engine begins to bog and the revs start to drop, the governor allows the throttle to open more and bring the revs up to 3600. Cool? Great. Going around the corner thru that thick grass with the throttle wide open, you hit that bare spot where the dog keeps peeing. The load comes off the engine, and as it begins to increase, the governor closes the throttle to prevent over-revving and holds at 3600 RPM. Got it?
If you examine your external throttle linkage, you will notice that there is no direct connection between the hand throttle control and the carb butterfly. Governor again. The hand throttle does nothing more than alter the spring tension between the governor arm and the throttle butterfly. Setting the manual control to "Idle" merely alters the spring tension from the governor enough to allow it to SET engine idle speed. The idle adjust screw is the bottom end rev limiter in that it sets the baseline that the governor drops to. I told you that to tell you this:
I recently had a situation that some folks might misdiagnose- an engine that refused to idle properly. After a barrage of time, abuse, and adjustments, the chinese Kohler clone on my kids' kart would not sit at idle. The kart constantly wanted to take off with no throttle input. At a glance, the idle was too high.
Close examination revealed that the idle stop screw on the carb was not doing anything- the butterfly just would not rest against it. If I pushed the lever by hand, it would sit at idle RPM, but as soon as I let go, it would take off again.
I tried to adjust the external governor components to no avail. With the arm off the shaft, something just did not feel right inside the engine. I pulled the engine off the kart and tore it down. I don't even know how to describe what had happened inside, but the governor guts were all over the place- literally.
By some miracle, nothing was really damaged. Short version of the story? I epoxied the "press-fit" governor gear shaft back into the side cover and reassembled everything. I (re-)adjusted the external components, and wouldn't you know it? Idles like it just came outta the shipping container at 1310 RPM, and maxing at 4230 as measured by my optical tach. Food for thought.
Jcotz
...wasn't there
NY
You could add this to your earlier sticky on governors.
tundrabeagle3
Ca
just to clarify does valve float also occur in ungoverned ohv clones at 5500 rpms with the stock springs?
r_chez_08
Should be in the shop...
Cornwall, UK
Thanks Toystory! This confirmed the idle issue on my gx160. The spring is a little damaged. Time to rip the governor out, YAY!!!
Screw billet, I like CAST! Way better! (typing this on OMB would be an instant ban lol)
Around then. Depends on age and quality of springs, weight of valves and valve train and other factors.
tundrabeagle3
Ca
thanks r_chez i was just curious... was planning on trying a stock 212 predator with governor removed, and didnt want every thing breaking apart
matman55
I dont have a camera!!
Mims FL
lol,i thought the govner on my craftmen riding mower was just some sort of emmisions bullcrap but this thread made me see that the govner makes my mower work at its best.
Ps.getin a little off topic here but those two colored screws on my weedie carb,are they removable so i can ajust the mixture?will it damage anything?
thanks-mat
thanks-mat
Start your own thread with some pics. Carbs are all different
