kids dune buggy help
thebull
i have a kids 2 seater dune buggy that has a 160cc honda motor the motor has a 11 tooth sprocket and the axel has a 54 tooth sprocket has lots of top end power, but has no take off power clutch is now shot. may have been getting bad before i received it. it needs a new one but im not sure what to get , this is off road use only it is a centrifugal clutch please help and advice.
ghostdog
you may want to change the rear sprocket to 60 - 70 tooth. Your torque increase would be great. You may want to also consider changing to a torque converter. Your power band would increase dramatically.
thebull
this cart is the runmaster 2 i think it is chinese made, just wanting something cheap and easy . it doesnt have the original motor my dad put the 160cc honda motor on it. would like to just buy a clutch that is geared correct and will last until kids out grow it. thanks for the advice i will keep an eye out for the tc
The crappiest of clutches will hold up nicely as long as the gear ratio is appropriate.
Can you post a pic of the kart, and give a rear tire diameter measurement?
