increasing speed
DS13
Annoying the Neighbors!!!
Elysburg, PA
I'm gonna be buying a harbor freight engine (one of the higher cc engines) so I know ill have enough torgue. I have already bought 9" tires and I am figuring on using a 5.2ish/1 ratio (I'm not totally sure about this yet but it is gonna be around 5.2). So my question is: Is there any other way to increase my top speed?
klicky96
Sandusky, Ohio
You could increase RPM by upgrading/modifying the engine.
Billet Flywheel, 18lb Valve Springs, Upgraded Con-Rod, maybe upgraded piston, upgraded valves, and re-jetted mikuni carb and you could probably be pushing around 6,000 RPM. Thats about 30 MPH.
Before getting into the engine upgrades, let's re-examine the kart. IIRC, you've got a race-style onroad affair with rather small tires, no?
With a 420cc engine, I really think that between tire size and gear ratio, you can get quite a bit of speed.
I seem to remember something about 9" tires- that is a really small diameter! With all of that potential, a 9" diameter tire is a very limiting factor.
You can also buy yourself another 400-600 RPM completely backing out the governor adjusting screw on the engine.
DS13
Elysburg, PA
Yeah its an on road style kart with the 9" tires(I'm kicking myself for jumping the gun on the tires) I'm thinking of a ratio of 5.2/1 but u think I should go higher because of all the torgue that that engine puts out?
Don't go higher. If anything, go slightly lower.
I have now said my last words on your gearing
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
... You can also buy yourself another 400-600 RPM completely backing out the governor adjusting screw on the engine...
:iagree: He's right. I remember you PM'ing me regarding this engine since I have the same one. People don't realize.. This engine has all kinds of potential in it, starting with the massive volume in the cylinder. Most engines which people post about on this site are usually under 7 HP and it's understandable to upgrade the parts in them since some people do it as a hobby, and some people have a budget which allows only that.
If an engine of this size is capable of producing 8500 watts, it has enough power to move you pretty fast. I currently (hopefully not much longer) have a 5.45:1 ratio and 15" tires on a dead axle and I got 38 mph with a flat tire. You don't need to open that crankcase for any reason, so don't you dare. :D
DS13
Elysburg, PA
Haha I won't I just wanted some input on what I could do... if anything I'm gonna increase my back tire size but not until I get some good use out of these ones I have now:thumbsup:
