CV Belt
91blaze
Indiana
I need a new CV belt that is 37" for the Comet 30. My dad says I can use a mower drive belt. Will that work? I found Comet belts online but it would be cheaper for me to just go to the mower shop. I just need to know if the belt will work. The cart is a Murray with a 6hp Tec.
91blaze
Indiana
I thought the angle might be a problem, just wasn't sure. I already looked up the belt I need, it's 203598A. I found a 203597A, so it should work well. The guy I got the cart from had a 26" mower belt on it. Don't know how it worked, but it did... until it broke. Thanks for the help.
Okay, let's put it this way-
While a mower belt may be able to get your kart moving, the CVT will not be able to perform anywhere near as well. Not even close.
In order to use a belt of a different length, you have to adjust your center distance to suit. This is the distance from dead center of one pulley to the other. You'd have to look up the required distance on the chart and see if it's even possible for you to adjust it that much.
Bottom line is, in order for a CVT to function correctly, the belt has to be exactly correct for your CVT setup. There is no error margin.
