Streaker 8HP Go Kart with Torque Converter
Which engine
  • Total voters
    11
exenos
Project Nut
That's precisely how accidents happen. Complacency. You're young. You'll learn.
As long as you walk lightly walking bare-foot through the shop is technically safer than shoes because you'll feel the piece of metal before you put your full weight on your foot. Now, in practice, since most people are heavy footed shoes would be a much better choice.
South Kart3377
Kart designer
Va
No problem, just wanted to ask because I offered it to you first. Maybe find a local machine shop that will mill down the stock head to bump the compression, or get a piece of glass, some emery and a lot of patience.
:iagree: grinding or welding would be horrible, and you could quite easily get something through your foot!
I do that at my uncle's shop I don't have a welder or grinder at my house.
I don't have a welder or grinder at this shop.
I second that.
You won't feel a tiny metal filing, no matter how lightly you tread, until a few days later when it appears as a large, infected welt, then you'll really feel it.
Take it from us older guys who have been there, done that:
Remember: To be old & wise you first must be young & stupid
ALWAYS wear enclosed shoes (steel caps if you have them) in a workshop environment.
Many years ago I was helping a workmate lift a bare 4 cylinder engine block, he slipped & dropped it on his foot, he was wearing steel caps & still broke 3 toes. The moral: s#!t happens. You can't predict the future but you can anticipate it
I was going to mention the metal filings that you get from grinding, drilling, wire wheeling etc. They are really sharp and they go into your skin so easily
Southkart, you have a noce looking kart there. You must be anxious to get it going.
Thanks for the pics :thumbsup:
exenos
Project Nut
By filing are you meaning the dust that is left after the grinding sparks have cooled?
South Kart3377
Kart designer
Va
Here is the current plan
The engine plan is
212 Predator Engine $99.99
Billet ARC Flywheel $95.00
NR Rev Kit 18lb springs $18.00
RLV Header $25.00
Mod 2 Cam $50.00
196 Clone Crankshaft $45.00
Hi-Flo Air Filter & Adapter $26.00
17.1 Millimeter Bored Carb $69.00
Billet ARC Con Rod $59.00
Honda Flat Top Piston $15.00
It will cost $491.99
I might do some stuff thats free, the reason for the 196 crank is so I don't have to mod the flywheel as I don't trust myself or anyone else to moddify something that will be spinning 8,000+ rpms.
See yall later
