nitro for a small chiness two stroke
I wouldn't hold my breath on that...
Part of the problem here- in fact the major problem, is the fact that you have no way of adjusting the A/F mixture when running on the nitrous. Nitrous oxide, when heated to combustion temps, breaks down into nitrogen, and oxygen (go figure). Effectively, you are shooting extra oxygen into the engine. You are NOT injecting more fuel. Result? Lean. At absolute best, you might experience a slight power increase depending on how much of that is shooting in, and whether your mixture is appropriate to begin with. As things get leaner, you're toying with overheating, detonation, and the ultimate possibility that you might have to get out of your kart and go back to pick up all the engine parts you scattered.
Want real, reliable performance? Do the engine up right, and leave the Dollar-Store nitrous junk for the back-alley dentists...
realfast89gt
Kart Krazy!!
cibolo Tx
Unless you have an extra engine laying around for when you explode the one you add nitrous to....
Nevermind i just looked at the kit........can i use those in my co2 pellet gun? Make a ntrous pelet gun....woohoo
bighead
Pacific Northwest USA
Go for it. Tell us how it works.
I have heard nothing but junk about those kits though. It would look cool to fool your friends though. I thought about putting one on my BSR just for looks but the price changed my mind.
ӍДҬӍДҊ⑤⑤
made ya look!!!!
mims
wow,i had no idea that im just putting more oxygn into the engine.i dont think that spending 60 bucks to ruin a 195 dollar M.A.B kitis the best thing to do.i have to admit that thing would look kinda cool with the "BOOST" sticker it comes with.
[edit] does anyone know what a boost bottle do?(i hear its just a empty bottle)
I have ZERO experience with the boost bottle, but it sounds like snake oil to me. With the passage to the bottle veing a very small hose as compared to the "large" carb venturi, even with the bottle vented to atmosphere, I just can't see it accepting anything tangible. Air, like water, takes the path of least resistance. If some mixture is being blown back toward the carb, I very strongly doubt it would divert thru a little orifice instead of heading straight for that great big venture. Add to that the speed at which the pulses are occurring, and I don't think anything would go up or down that little hose.
Speculation, to be sure- but I just can't see it...
