need help on engine.
Rubidoj
Miami, Fl
ive been looking aroung for engine and trannys and want opinions as to how good they work.this is the first one i know its pricey and all but want something with a tranny.
http://www.bmikarts.com/item/GY6-150cc-Engine-200020-6578
and whats the difference with this one?
http://www.scooterdomain.com/Engine_150cc_GY6_P57QMJ_Short_Case_Version_p/en-p57qmj-150-l.htm
http://www.scooterdomain.com/Engine_150cc_GY6_P57QMJ_Short_Case_Version_p/en-p57qmj-150.htm
is there any other alternatives you guys would suggest?
and im building a 2 seater go kart buggy. im designing the buggy with my 5 year old stepson (he wants a monster truck so he can run over trees lmao) im using ZW3D to model it and show u guys but i should have a sketch up by tonight if i get my p.o.s. camera to work.
klicky96
Sandusky, Ohio
The difference is, one is a short-block, one is a long block. The short block can be used in smaller, compact places, like a scooter, small racing kart, etc.
Rubidoj
Miami, Fl
when it comes to performance parts for the predator, where can i find some? i found a bunch for the gy6 but no luck on the 420.
Rubidoj
Miami, Fl
ive also been thinking of a twin engine but using dead axles on each side but have no knowledge of a company that has the same engine with opposing shafts or is there another way about this?
klicky96
Sandusky, Ohio
You could use the 420 Predator with dead axles on both sides. From engine to jackshaft input, jackshaft sprocket left to wheel left, jackshaft sprocket right to wheel right.
Rubidoj
Miami, Fl
is there a way i can see this in a diagram lol i cant visualize this at all :confused::ack2:
Or you could use one 420 in the conventional way on the left wheel, and then use another 420 on the right using a jackshaft to route the chain to the left wheel.
You can maybe visualise it if you look at my minibike jackshaft. I had to use one to get the chain onto the sprocket that was on the right hand side of the wheel, but the engine PTO was on the left. This is sort of what you will have to overcome.
Ignore my gearing on the jackshaft. It was all wrong at the time I took these pics, but you get the idea
r_chez_08
Should be in the shop...
Cornwall, UK
Pretty sure in this case the short block is one without the head and possibly other parts. People often buy them to replace an old long block and use the external parts from the long block. This explains the cheaper price.
Some gx390 performance parts fit, and I think there are some specific predator parts now (definently for the 212, maybe for the 420).
Try NR racing, Arc racing, affordable go karts, and google gx390 performance parts.
