You don't need to fix them, they're not broken. You need to get everything realigned properly. WARNING: RANT COMING!!!!!
I took out the governor ... I didnt know how to reinsert the cam .... I do not know anything about small engines. How can i fix it?
Why in Dog's name do people insist on doing this stuff? No instruction, no experience, no manual, no notes, no pics. No kidding. I understand that we're all "new" at some point and don't understand how things work or go together. But seriously- the greatest dang tool you can own is a service manual! If you had it, you'd already be racing down the street, instead of helplessly watching parts roll off the workbench. In the absence of a manual, some knowledge and experience is a must. Even then, it's always advisable for the less-experienced to take notes and photographs as things come apart to see exactly how things go together properly. Now, you're hoping like heck that somebody can help you, or else
Please, people, PLEASE- Arm yourselves with a service manual if you do not know what you are doing! Even us experienced people reach for a manual and/or spec sheet when doing engine surgery. How do you know what the torque spec for the bolts is? How do you know what the points gap spec is? Or the ring end gap? Or valve lash? MANUAL people!!!
Ok, that's outta the way. Now-
Orient the crankshaft so the piston is at the top of the stroke. Open up the rocker cover so you can see the rockers. Push the lifters (tappets) back in, and all the way up into the guides. See the dot on the crankshaft gear? See the dot on the cam gear? Insert the camshaft so those two alignment marks are against each other with the gears meshed. Now, look at the rocker arms. If necessary, move them so that one end of each arm is riding on the tip of the lifter, and the other end is on the valve stem (as they may have rotated out of the way). NOW the whole thing is properly aligned and timed. Put it back together with a new gasket if need be, and beg, borrow, or steal a torque wrench. Torque the cover bolts down a bit at a time in a criss-crossing pattern until they are torqued to the specification for your engine. Do not forget to refill the 'case with the correct amount of the specified oil.
