speed1
Have been using the speed calculator on here (great tool) want to acheive around 30 mph for street riding...Have 1 go-kart set-up as follows : 15"tires , 3600 rpm, 72 t sprocket and 12 t centrifical clutch and according to my GPS it gives me 25.4 MPH...The new 1 we are building I would like to achieve 32 MPH...To do that I would need to put a 60 t sprocket on it and the rest the same as the other kart I have...My question is this...The 60t sprocket calculates to 32 mph with 15" tires, 12t clutch and 3600 RPM . will that give me ENOUGH TAKE-OFF power, or should I usr a 72t sprocket (which takes off fine now) and remove the governor from the 212 cc HF engine with the 60t sprocket? Thanking you in advance for your expertise...Bob
