Here is a "before" shot of the aquisition. A vintage Manco "Corvette". The roll bar has been removed but other wise everything else is stock and intact. The body is long gone, but, we will be restoring the frame and functionality over the next several months! Hopefully. What I have found out so far is the hardest replacement parts to restore this kart are the 6" split aluminum rims.
Front View:
Side View:
Steering Wheel:
Rear View:
Cracked Rim:
I have found the following replacement parts:
Seat
Bearings
Muffler
Throtle Cable
Brake Band
Clutch
Chain
Tubes & Tires
and some other parts.
I need a wheel rim half still.
The frame will undergo a stripping and the spindles will be removed and reworked and all bolts, nuts, washers, etc will be replaced. Engine will be reworked as well.
Front View:
Side View:
Steering Wheel:
Rear View:
Cracked Rim:
Seat
Bearings
Muffler
Throtle Cable
Brake Band
Clutch
Chain
Tubes & Tires
