4 different exhausts which is better ????
kartmonster13
ok guys i have different exhausts i have a staight plumbing pipe on right now but its only about 9.5 inches and i have these other three i have a curly one on my racing go cart with the trx200 motor on it and it sounds loud and nasty top one is a old kx125 muffler and the straight pipe with tip came with this cart just not on it
kartmonster13
its a 5hp briggs fun power it already has a 9.5 inch straight plumbing pipe on it
Honestly, I don't think any of those would be suitably because they'll hang off the back by about 2 feet. Stick with what you have or, if you really want to change it, go custom
I'd use that 3-stage header with the RLV race muffler in the center of your pic, the pipe with the loop is much larger diamiter and would be better suited for a full race engine.
kartmonster13
will it give it more power? or maybe run better? ive seen people talking about it needs to be around 14 inches or so
You might notice a little difference over your old pipe with a stock engine. Guys that build racekart engines for a living use all kinds of different length/design headers trying to squeeze an extra 1/10hp dyno readings at specific rpm ranges, but a 14" length is probably a pretty good guess when building a simple homemade pipe.
jamyers
Buffalo Gap, TX
If you use anything much longer than stock, you'll REALLY want to brace it. Having it strip itself out of the block ain't fun.
Cheap / Easy braces can be made from something like metal conduit and a hose clamp, like I did here. Use a BFH to shape the conduit, drill and bolt one end, clamp the other. Even then, after running it awhile I needed to brace it for sideways movement, so I added another brace going down to the right-hand side frame rail just aft of the axle bearing.
