Engines, Clutches and gearing.
ThunderGoatz
Im planning my first build, and i was wondering about gearing. I will be running a 6.5 clone, with a 10 tooth clutch, and a 60 tooth sprocket on a diff axle running 10.5 inch slicks. (road kart)
Engine: http://www.bmikarts.com/item/Yellow-Clone-Dupor-196cc-OHV-Racing-Engine-ADJ-1001-7445
Sprocket: http://www.northerntool.com/shop/tools/product_26107_26107
Clutch: http://www.northerntool.com/shop/tools/product_200310374_200310374
how does this sound? will i be okay in terms of gearing? THANKS!
r_chez_08
Should be in the shop...
Cornwall, UK
Sounds good. BMI are cheaper for the clutch and sprocket and then you can have all one order.
You could use a 54t. Anything 8.5" or bigger should be good.
ThunderGoatz
the thing is i cant find another sprocket that will fit the diff axle, and im most likely going to be running 12.5 rears now.
Please explain. Are you referring to space to mount it or the diameter of the axle?
Mounting a sprocket to a Peerless 100 differential requires a specialized sprocket bore and an odd bolt pattern. Not just any sprocket will fit.
When I did mine, I found a weld-on type sprocket that had a bore just slightly smaller than the shoulder on the Peerless. I had to carefully file down the shoulder on the Peerless to make the bore fit. Then, I had to use a transfer punch to copy the bolt hole pattern and drill them out.
