jackshaft gear ratio
tspot100
my son and i are having trouble figuring out which gears to use on our go cart with a 6.5hp motor and jackshaft. searched online but am still confused...
started with a 12t clutch, 16t jackshaft in, 18t jackshaft out to a 45t axle sprocket. 18inch rear tires
lousy acceleration but very high top speed...exactly opposite how we want it.
going to swap the 16t for a 13t on the jackshaft in.
will this go in the right direction for our gear ratio?
the axle sprocket is difficult to change out so we'd like to just change the jackshaft gears if possible.
tried these online gear ratio calc w ith no luck..
thanks in advance...
klicky96
Sandusky, Ohio
Swap around the 16T and the 18T. you want a small on the engine going into a large on the jackshaft. then a small from the jackshaft going to a large axle sprocket. You need to have a larger input sprocket than the output sprocket on the jackshaft.
All my calculations are using your old 12T clutch and 45T axle sprocket and 18" tires, and are a theoretical top speed at 3600 rpm.
Your old gearing had an estimated top speed 56mph @ 3600 rpm.
If you simply swap the 16 and 18 in place of each other, you'd be geared for an estimated 44mph top speed.
Using your 18-tooth on the jack shaft input, and a 10-t on the jackshaft out = 28mph.
_________
Using same 10-tooth J/S-out on all options below:
20T J/S in = 25mph.
24T J/S in = 21mph
28T J/S in + 18mph.
32T J/S in = 16mph
36T J/S in = 14mph.
tspot100
thanks for the replies. i am running a #35 chain from clutch to JS in, and a #40 chain from js out to axle. can't swap the 16 and 18 as they are different chain pitch.. just ordered some additional gears. all i could find was a #35 20t gear and a 9 or 10t #45 for the JS out to axle. will let you know how it works...
tried a 10t clutch to a 17t js in , 14t js out to 45t axle. better torque but still smoked the clutch...what i had laying around...
if this doesn't give us the ratio we need..may look into a torque converter
tspot100
wow! great selection of gears. ordered a variety ..
a 9t and 10t for JS out and a 20t, 22t, and 24t for JS in.
hoping this will give us the ratio we want...
thanks for the help...
tspot100
thanks for all your help. finally obtained the gears i need. i ended up with a 12t #35 clutch to a 24t #35 jackshaft in, to a 9t #40 JSout to a 45t #45 axle sprocket. i think that gives me a 10:1 ratio???
great low end torque and decent speed. just what puts a smile on my 13yo's face!
picked up a comet TC but i think we'll keep the jackshaft on for a while...
now to work on the anemic brakes!!! it has a 4"drum with a band type brake. work terrible.. any ideas? hydrolic?
