Mounting a bigger engine on my Kart.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
Finalyyy, my 420cc Predator arrived today and as expected, my old mounting plate is too small for it. I have a 1ft x 1ft piece of steeland I think its strong enough to support the 90 lb engine. My question is, how do I go about making the holes perfectly aligned on the plate as they are on the engine? Is there a template that I can print or something so I can mark the spots on the plate? I'm not sure what to do about it.
treyfus
Augusta GA
i would use a silver sharpie, they are very visible. use calipers if you have them, or tape, and measure the motor mount, and create a drawing of it, then cut out your plate, measure, mark, measure again, drill, and weld!
Brandon1023
needs an oil change
Alright. Ill give the sharpie a go. If it fails, the inner ink cartridge of the marker held with some needle nose pliers will do the trick. Will get back to everyone and share how I finished my task.
qtband
St. Louis, MO
I take a piece of paper, put the engine on it's side, then hold the paper against the engine and use my finger to press in on each mounting hole, thus making a mark on the paper. That gives me a template.
:iagree: That's the way to do it, old panel beaters trick. Works even better with a dirty finger.
Go over the whole mounting area, that way you will know exactly where it will fit on the plate
SquareTire
^^ good technique, you could also install 4 bolts into your motor, then put it on top of your 1x1 steel plate (bolts will act like legs on a table holding your motor up) then trace around the bolts directly onto your place, then drill away...
