4-stroke problem with valves
Fallenleopard
N.S.W Australia
okay so I have some photos here explaining my problem. I have played around with 2 strokes for a while and just decided to take a look at a 4 stroke mower (not working obviously)
I ran into an issue with the valves there is 2 directly next to the piston i am assuming one is for intake and one for exhaust??
please correct me if I am wrong
the top one goes in and out as i think it should (and is not loose) but the bottom one is able to come out then does not go back in!
i am also able to pull this one out without using any force!
please could someone explain to me why this is happening and if i can and how i can fix it
thanks!!
r97
Measure twice cut once
Massachusetts, USA
You should take a look in the valve spring cover, I would bet the lower (exhaust?) valve has detached itself from the spring.
klicky96
Sandusky, Ohio
This is probably what happened. The clip may have just popped off. Pop it back on and you may have a running engine. But, while you have it taken apart, I'd clean it up.
robbie
Osceola, Missouri
Take the cover plate off, next to the muffler. When you look inside, you'll be able to see the difference between the 2 valves, and you'll know what's wrong. It's probably just a broken clip.
Fallenleopard
N.S.W Australia
I have taken the side panel off and I can see the two springs on the broken one the spring does not compress and move forward like the other one
Is there any way I can fix this
robbie
Osceola, Missouri
Can you post a photo of what it looks like inside?
Usually the way to fix something is to replace whatever is broken with a new one.
