Is 15hp too much for one wheel?
grubbyfoot420
Alright so this is my first build and I currently have a regular old frame for a regular old kart it isnt a racing frame nothing special and its set up to have only one wheel pull. My uncle is selling me a modified briggs set up for a race kart pumpin out about 15 horse running gas and god knows how much if I put the alcohol carb on it and I need to know if 15 hp is way too much for only one wheel. If it is, then how hard would it be to convert it to a live axle and what would I need? And Im gonna put this little guy because hes a badass and there is no denying it. XD :2guns:
Badot
Well... my car has 130hp going through two wheels... so 65 in one wheel?
But in all seriousness, it depends on a lot of stuff. Obviously the more power you put through lopsided the more the kart may want to steer on its own and the more obvious the traction issus will become.
So long as the kart parts will hold up, if you can set it up on one wheel without any real cost to you it may be worth trying just to see if it's acceptable or not. If you're happy with it you can save yourself a lot of work in most cases.
If you're using it offroad though, I think you'd be happier with a live axle, but tight corners on hard surfaces can be a pain with a live axle.
cmbone
WA
I combined a kart with a RM 250cc dirtbike. 15hp. (one tire fryer). I used it for dirt mostly. I put a agressive tread tire on it. It would climb most any steep dirt hill. If you stayed on the gas hard. But if you stopped on a steep hill, you will just dig a large hole.
I flipped it on pavement once, turning to sharp. Man would that kart roost some dirt!
I sure do miss that beast. :(
klicky96
Sandusky, Ohio
The problem with this would be the axle-shaft bending from all of the torque. In my opinion, I'd do it just to see what'll happen.
Bluethunder3320
i think a RM250 makes waaay more than 15hp
cmbone
WA
I dident want to egzagerate lol.
:iagree:Hi, This was a late 70's RM, but it very well could have had more HP then 15. I think the new ones have more like 30
I never bent an axle, The kart was an old rental kart. (Race O Rama) i used to work there as a kid. Heavy, but i dident matter with that power. It had 3 slicks & one small tractor tire.
My dad just kept saying~
:Your going to kill yourself on that thing::toetap05:
