ex250 go kart
move_out
hey every one im new to this website at the moment im building a go kart using a Kawasaki 250 motor the problem im having is finding a 520 pitch sprocket to fit on my rear axel if anyone could help it will be much appreciative.
dinot71
I was wondering the same thing...Can a motorcycle sprocket be made to work on a go cart engine? Is your Kawasaki from a dirt bike? If it is then you should have no problem using a 520 sprocket/chain.
move_out
its not from a dirtbike its from a road bike wich uses a 520 chain but most go karts use i think 420
You can buy #520 sprockets here:--> http://www.gokartgalaxy.com/shifter_kart_&_quarter_midget_sprockets_for_3.htm
If you post some pics/measurements of your rear axle style, we could probably recommend a sprocket hub to use with those...
We could probably help you select how many teeth your rear sprocket should be If you post:
Your engines current drive sprocket tooth count, and its redline rpm,
and your rear tires height, and approx weight of the kart/rider(s) ?
and kinda give us more of an idea if the kart will just be for pavement use, or maybe just for serious off-road type riding.
Etcetera, any other info like that would help us to help you out here :thumbsup:
redsox985
PA
I would actually say most go karts use 35, some use 40, but any with a bike style engine uses 420/428/5##, whatever the bike uses.
88s10Durango
Chilliwack BC Canada
Those prices on that site for 520 sprockets is high , personally go on Ebay and check there , I found a 520 front , rear and chain in a package deal for a motorcycle on Ebay for $ 59.99 ,alot cheaper .
move_out
hey everyone sorry for the late reply didn't relize I had a thread lol. the sprocket on the motor is a 15t the motor redlines at 14,000 the kart would probly weigh about 80kg and the wheels are I think 8" its for road use only atm I would like to have acceleration as well as a good top speed ill give pics soon thanks for the help
move_out
this is some pics abit old but
move_out
haha yeap and btw do you think 30tooth on the rear axel would give me good acceleraton plus adecent top speed ?
Racekart slicks like your rears are usually around 11 inches tall, not 8"...
So assuming your rear tires are actually 11" tall, anywhere between a 25 and 30-tooth axle sprocket would be a good choice.
move_out
thanks anderkart lol well,i got a 45t on it atm and its poping wheelies lol but it revs out to quickly lol
EvoDre
lol idk why he placed the motor there in the first place, i wish that is not what happened to him though!
