4 cylinder engine and tranny
Bluethunder3320
i happened to find this today in the woods, 4 cylinder and i think a manual transmission.
it looks just like an isuzu pup engine that i helped replace the head gasket on recently.
got 3 guys and tried to lift it on top of my craftsman but we couldnt get it on. we need to get a wagon or something.
if its a head gasket, i can pretty easily replace that but from how it looks it needs to be 100% torn down anyways. valve cover needs some patching done to it. i think a go kart would be waaay too over powered with this.
home built tractor? i need a job first haha but that would be pretty awesome.
the intake manifold is broken in half, im taking welding at trade school next year so maybe i could fix it. the exhaust manifold is fine, all the emissions stuff is broken off but WHO CARES as long as im not using it in a car on the road that needs emissions tests.
over the weekend we will go back and try to lift it again. its not insanely heavy, just too much to lift 5 feet high
karl
North east Ohio
I would almost scrap it for some good money, it would probally cost more to fix it up than to buy a scrapyard engine in the first place. All the electronics, accessories,ect. And theres a hole in the valve cover, and theres probably a reason why it was sitting there. Scrap it for over $100, IMO.
Bluethunder3320
when i get it i plan to maybe just pull the head and check things out. try to get it to at least turn over.
if its blown up or too much broken, scrap.
i know i could probably do a pretty good job cleaning it up
karl
North east Ohio
Yep, Should take haft an hour or less to pull the head and inspect the damage, if it is rip off any ok parts and send it to the scrapyard, right now its at 13 cents a pound where I live, so you should get some serious money if you strip the transmission to get the aluminum, witch is 50 cents a pound here.
Bluethunder3320
thats pretty awesome. i dont know if there is even a scrap yard anywhere near me, ill have to check.
B.M.800
TheBeal.
Central PA
If theres is a scrap year near you, dont just strip it apart and take it in... if you can, stash it and add to it, till you get a few hunnerd pounds of it.
I doubt it would be worth it alone... I dont think theres $30 of scrap there...
Bluethunder3320
wait wouldnt more pollution thicken the ozone layer? haha.
tomorrow gonna try to load it onto a wagon and use the craftsman hydro to tow it home
Bluethunder3320
wasnt able to go yesterday. and the craftsman is in my friends garage but he is going to italy for a week.
i did get the carb home, hopefully getting the rest on a wagon and pulling it home...
Jake.B
California-USA
Do you have a long sheet of cardboard or a matress anything you could tie a rope to? If so do you have a quad or offroad go-kart? You could just slide
It home?
Bluethunder3320
got a tractor but it goes too fast. 10hp mini bike that will tow it but my parents wouldnt allow me to bring it there. hydro tractor is at my friends but hes on vaca.
so i have a wagon that will do. lol.
btw jake i shipped your carb this morning
Bluethunder3320
more of this yummy Isuzu
redneck tranny removal
up she goes
boom
later that night i removed the rocker arms, one is broken. also the camshaft has snapped off a pretty important piece that was rusted into the head. and of course, part of the head broke off as well.
one headbolt stripped out, so i wasnt able to remove the head.
one oil pan bolt stripped out, so i wasnt able to check the bottom end.
the headgasket has been unfortunately ruined but it looks BRAND NEW.
while removing the camshaft the timing chain crumbled into bits. :(
so far need:
timing chain
one rocker arm
camshaft
alternator
starter
electrics
one head bolt
head
head gasket
valve cover gasket
maybe a new valve cover
Bluethunder3320
Ever wonder why it was in the woods?
maybe the broken rocker arm made it run like crap so they threw it out there. who knows really.
by tomorrow it will be 99% apart so i will get to see the cylinders and bottom end. if those are bad then everything is bad.... haha
these specs seem very close.
Engine Code: G180Z
Engine Displacement: 110.8CU IN / 1816cc OHC
Fuel System Type: Carburettor
Power: 59.66 kw @ 4800RPM
Torque: 95ft. lbs. @ 3000RPM
Bore x Stroke (in.): 3.31 x 3.23
Compression Ratio: 8.5:1
Oil Pressure: 57psi @ 1400RPM
Spark Plug Type: BPR-6ES11 (NGK)
Spark Plug Gap: 0.040 (in.)
Ignition Timing: 6 degrees
Intake Valve Opens: 21 degrees
Compression Pressure: 170PSI
Idle Engine Speed: 800RPM (manual gearbox) 900RPM (Automatic)
Valve Clearance (in.) (Cold): Intake: 0.006 Exhaust: 0.010
Bluethunder3320
or this
Engine Code: G200Z
Engine Displacement: 118.9CU IN / 1949cc OHC
Power: 61 kw @ 4600RPM
Torque: 101 ft.lbs. @ 3000RPM
Bore x Stroke (in.): 3.42 x 3.23
Compression Ratio: 8.4:1
Oil Pressure: 56PSI @ 1400RPM
Spark Plug Gap (in.): 0.040
Idle Speed: 800RPM (Manual) 900RPM (Automatic)
Valve Clearance (in.) (Cold): Intake - 0.006 Exhaust - 0.010
exenos
Project Nut
I think that's just scrap. It looks like the pistons are so rusted in that you wont be able to remove them.
EDIT: Nice wagon :)
Bluethunder3320
Holy crap, Matt- Know when to say, "When!" I think my computer needs a tetanus shot now!
my friend cut himself on the oil pump gear lol. scary. its sharp as a razor
yeah, we were pretty determined to get this cleaned up and running. but oh well, i think we have done all we can.
need to find a scrap yard, ill bring some of my mower decks too
Bluethunder3320
I think that's just scrap. It looks like the pistons are so Austen in that you wont be able to remove them.
EDIT: Nice wagon :)
agreed. even the easiest piston has no chance of moving. and #1 and #4 cylinders have cracked making it nearly impossible.
i have confirmed this engine is a G200, 2.0L. found in some 70's and 80's GM and Isuzu cars
