Inserting the Cam
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
So I decided to completely dismantle my little brother's 5.0 since he just got a pressure cleaner engine thrown on his kart. But that's another story :p My question is.. I decided to open the crank case to clean it out. Don't ask why.. I just want to clean the whole engine since I'm suspended from school. While I was pouring some drops of oil in to the storm drain (I know it's bad to do that.) the cam shaft happened to fall out of the case and the compression release weight fell in to the drain. I don't think I need one that badly. If it's a problem, I'll replace it. Now the actual question is: Does the camshaft need to be inserted a special way in relation to the coil? Will it time properly if I just stick the cam in there? I know it's important so this is why I'm asking. Thanks.
r_chez_08
Should be in the shop...
Cornwall, UK
You may struggle without the compression release.
There is usually a dot on the camshaft and a dot on the crankshaft to line up, or two distinct markings.
Edit:russ beat me to it!
karl
North east Ohio
Dont worry bout it, just makes it alittle easier to pull start, it will run the same without it.
r_chez_08
Cornwall, UK
Basically it opens the exhaust valve a little bit when the motor is on compression stroke, which decompressed a bit. It may be still ok to pull start.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Jake.B
California-USA
Dump oil down the storm drain wtf is wrong with people. The reason you lost the compression release is called Carma.
brandongeiger2
Valrico Florida
Trust me youll want the comperession release i lost the one on my 6.0hp tecumseh(i know call me stupid haha) and it about pulled my hand off every time i tried to start it also soon after the thing blew up(i don't know if it was a coincidence or because it burnt up the valves)
Brandon1023
needs an oil change
Now there's no suction or compression.. I matched up the dot on the cam and crank and nothing. I have someone spin the engine while my finger is over the hole and there's nothing going on. If I take the push rods out, then there's intake/compression. What's up with that?
brandongeiger2
Valrico Florida
well thats because the push rods actuate the valves...those are what allow for intake and exhaust my guess is the cam and crank are improperly lined up because if they are they could be prematurely opening causing a significant loss in compression .
And what hole the spark plug hole?
Brandon1023
needs an oil change
Ok so it seems like on the intake cycle, the rod doesnt move. Then when the compression cycle is happening, the rod on the intake valve is going on. I don't get it. I lined up each timing mark on the cam and crank.
