...Anybody here "more" circumcised?...
Micro-rant over. Have a great weekend!
tAnybody here "more" circumcised?... [/QUOTE said:Well I'm larger than most, so I guess i'm more circumcised![]()
You should attach the tie rods to the bell crank with one center hole. The way you are set up now you have ackerman at the spindles and you are adding more at the steering shaft bell crank. The stops don't effect ackerman.
For the record-
"Reverse Ackermann" does NOT refer to the condition created when steering arms face forward, and/or measurements/adjustments to suit. The phrase "reverse Ackermann" indicates a steering setup wherein the outside tire steers more sharply than the inside tire- which in almost all situations is entirely UNdesirable.
You can achieve ackerman at the spindles and at the bellcrank. Now if you do both then the inner tire has to much angle and the outer one has not enough. If you look at my steering i have my ackerman in the bell crank. My spindles are from AZUSA and the arms of these come off at 90 deg.
its much easier when building a kart to build the ackermann into the steering arms. im not even sure how you would build the correct ackermann into the bellcrank, but every time i messed with adding ackermann angle with the bellcrank, it would give me reverse ackermann.
what i described with the steering arms facing forward is reverse ackermann, which is exactly what you described as well. using the term "anti ackermann" was from another article i read... descibing how to reverse the effects of "reverse ackermann" im sorry that you felt the need to rant, but i think we are saying the same thing different ways. i didnt mean to cause confusion, im simply trying to help.
so have you measured your ackermann to see if its correct? ive found that its much easier when building a kart to build the ackermann into the steering arms. im not even sure how you would build the correct ackermann into the bellcrank, but every time i messed with adding ackermann angle with the bellcrank, it would give me reverse ackermann.
I put the ackerman into the bell crank because I was using AZUSA spindles.
This is what I did to figure out how to make the bell crank:
Draw a line from the spindle to the center of the axle shaft. Calculate that angle to the centerline of the kart, It might be 15 deg.(Guess) Use this measurement to calculate the holes in the bell crank. Each hole should be 15 deg from center of the steering shaft or 30 deg. apart.
Is there any rule of thumb by which to set the distance from the center of the steering column to the holes? Is there a relation between that distance and the distance between the kingpin center to the tie rod connection point on the steering arm?
