a few engine questions.
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
You want the bad news???? :roflol:
METRIC drops? You're telling me there's metric drops?
Wait a minit- Lost here- Four strokes equals one revolution- and we (Yeah. We. LOL) were trying to determine fuel consumption per revolution. Why'd we just divide by four?
Lets hear it.
Yep. The size of a drop varies greatly, depending on fluid being measured and current conditions. http://en.wikipedia.org/wiki/Drop_(volume)
Each cylinder takes 2 revolutions to complete a cycle, so given a single revolution, 4 cylinders take in a/f mixture. Hence 3.2 drops per revolution, divide it by 4, so .8 drops per cylinder per combustion cycle.
devino246
Lynchburg, VA
Wow that was some pretty impressive math. ****.. lol. Can someone send me a link to some info about gear ratios? I know a bit about them, but not nearly as much as id like to know. Ust tryin to educate myself here.
Assuming you paid attention in math class, you should know a little about basic ratios. There's nothing complicated.
If a vehicle is geared 3:1 from the engine to the axle, that means that for every turn of the axle, the engine turns 3 times.
Devino, you gotta get out more. LOL
Impressive stuff! I had a rough day today, don't expect too much outta me. I'll be glad when the rent-a-kid is outta my house. Come to think of it, I dammed glad I'm back to work tomorrow...
devino246
Lynchburg, VA
Prolly true:roflol:
Rent-a-kid??
Yeah- in addition to my own headaches. Had to get the whole crew back from 1.5hrs north last night, with a charging system malfunction in my truck. No stress.Nothing more infuriating than trying to diagnose an intermittent electrical problem. Figured it out this morning and managed to repair it, but not before gaining a few grey hairs...
FTR- this was the SECOND time in my life I have successfully diagnosed an intermittent electrical problem with a hammer, when conventional test methods yielded no tangible results.
Brandon1023
needs an oil change
Miami, Florida, Dade County 305
I have another question if someone would like to answer it. (This is a very interesting thread. Why not keep it going? Lol) Would a V8 gasoline be less fuel efficient than a V8 Diesel? Let's take a '99 Ford Excursion for example. They offer both types of engines. I know Diesel is more powerful for Torque and such means, so why do they make big SUVs and Pickup trucks with Gasoline V8s? I heard Diesel burns slower. I don't see how that works if the cylinder is emptied with the exhaust cycle. Sorry I'm so full of questions. Been tryin to figure this all out lately.
devino246
Lynchburg, VA
Yep, Diesel engines are generally much more efficient than their gasoline counter-parts. Diesel fuel actually has a higher energy density than gas. One gallon of diesel contains around 147,000 BTU, while one gallon of gas contains 125,000 BTU. Diesel engines rely on the heat and compression of the engine to ignite the a/f mixture, as opposed to gas engines which require sparkplugs.
Can't stand 'em! Actually since it's your thread, you can pretty much talk about anything you want! (except politics, site "no-no"). I may move this to "Off Topic", though...
sexyvicta
...Or more prosaically, 'transverse mounted'.
First time I saw this configuration, it was in a '62 Mini Cooper (first built was in '59) with a 4 speed manual trans.
Similar to this:
original minis are just called minis(or sometimes austin 7, reily elf etc etc) . The mini Cooper and cooper S were like a go fast model with special bits made/designed by Cooper(the f1 constructor from the 50s and 60s). Kind of like a Shelby Mustang.
Rustydog2010
NZ Nutta :|
New Zealand
For example, in my neighbor's lexus, he has an inline V6.
He has a what?
Inline 6:
V6:
I think i know what you meant, but will just clarify anyway, cause im bored. :D
