Thats a good idea about making adjustable shock mounts. I definately want to do away with the stock shocks and get some better ones on there.
Ill do a writup with lots of pics when i do the extended j-arms on there. Looks pretty straightforward and i should just be able to cut the stock one, add some tube, and weld together, and add a brace. Since im doing a custom roll cage i was planning on doing the shock mounts, etc to that instead of how they are now.
To answer your question about the frame. No, i do not have the frame but i got the engine with the cradle from the frame so it works out great. Im going to use that to build the mounts off of. You may be able to see it in the pics if you look close.
here are some pics of the rough mockup. The engine will actually sit about 5-6" higher to gain some ground clearance and make sure i dont tear the oil pan off it... And im going to get a +4" axle once im finished with the mockup and it actually becomes a roller.
