Engine Problems!!
jrmints1415
Naperville Illinois
I disconnected the governor on my 6.5 lifan but did not remove the actual gear or arm coming out of the block. I hooked up my throttle again the right way using a pivot and the old rod connecting to the butterfly valve. I go to pull start it and it goes for about two sparks then cuts off. What did i do wrong?? I know its not my throttle conection because i have done the same connection with a different motor that ran perfect except with that one i removed the governor completely which leads me to believe its something internal... anyone know how to solve this problem??
See above starting note- With the governor intact and the engine off, the throttle rests open a bit, then closes to idle when the engine starts and governor acts. With no governor, your throttle is sitting closed. Try holding it open 1/4-1/3 and attempt to start.
Actions speak louder than words. Listen a lot without talking. Make it dinner. Bring it flowers for no apparent reason. Next thing you know, she'll be all warmed up and ready to go for you!
devino246
Official DIYGK Chem Nerd
Lynchburg, VA
Id empty my entire bank account to see someone actually do that.:roflol::roflol:
kendelrk
redneck engineer
westland michigan
on my first small engine, i blew a head gasket which made it extremely hard to start and i couldn't pull it hard enough, but it used to start up for my friend when he sang barracuda to it. So we call him the engine singer
panman9
haha **** thats funny
