tie rod help
JMack1995
Melbourne, Vic, Australia
hey i was wondering if it maters if i put the tie rods in front of the front wheels or behind them. i dont think this would affect anything but would like to hear other opinions
Cheers
Josh
jman231994
Australia
Yea like landuse said, It wont matter. I'd just like to give a tip which you probably already understand but I've seen it done wrong a few times before so I figured I would anyway. Haha
If your pitman arm (one off the end of the steering shaft) goes forward or up then all the arms off the wheels should go forward. If the pitman arm goes back or down then all the arms off the wheels should go backwards. It's pretty obvious, I dont think it was what your question was, but it could save a major headache with clearances later on :thumbsup:
PistonPete123
Crash Test Dummy
Ellenton, FL
LOL to what jman231994 said, hook it up wrong and turn left go right, i would like to see the look on someones face when they take it out for a test drive.
I would like to meet the guy that gets all the way to the point of test drive before actually noticing. Wouldn't you be completely unable to ignore it once the rods are on? Wouldn't you then give the wheel a twist to make sure things move smoothly?
fowler
Bullsbrook West Aus
starts engine gets in
guns the throttle
gets to end of street
turns left
careers into sign on right hand side of road
sign say LEFT TURN ONLY just to make him look like more of an idiot
