My Tc won't engage?
B man
Tecumseh FTW!
Oliver springs,Tn
Ok so i just bought a new weight pack and belt to fix my problems,but they got worse.
when its up on a stand the clutch works great!
But when i droped it down on the ground it wont engage. it only VERY BARELY engages. not enough to do anything, it drives around,but its slow and stays in low.
any ideas? :surrender:
augidog
is the engine still giving you the rpm's you're used to? i believe the springs that shipped with your weights were stock 2400. maybe the old springs were for a lower engagement?
i'd try the old springs on the new weights to see what happens.
B man
Tecumseh FTW!
Oliver springs,Tn
idk. i know the engine is pushing the right rpms. and it actually is now driving great.(its engaging a bit more) i think its just weight,gearing,and wearing the weight pack in.
its geared at 4.500. 10t to a 45t axle. i way about 200lbs and the kart isnt exactly light ether.
B man
Tecumseh FTW!
Oliver springs,Tn
plus my drivens buttons are wore.(but they still make good contact)
and my drivens spring is also kind wore but it works ok.
and they are slightly out of align .
Blazkowiez
Kart Aficionado
Houston, Texas
Check that the driven clutch does open properly. However it sounds very much like your engine is having problems with power or you've some a key sheared.
B man
Tecumseh FTW!
Oliver springs,Tn
well it has plenty 6.5hp harbor freight. i even have the throttle stop turned out. but could the springs really be that strong?
it works perfect on the stand.
i just dont get it. i mean it could use a new driven spring,but i don't think it cause all this trouble.
Blazkowiez
Kart Aficionado
Houston, Texas
In the driver clutch. I've seen this happen several times before. If you have no idea regarding your torque place a tachometer on the engine to check what its really turning out. If you've got blue tip springs they'll engage at 2200 rpm.
B man
Tecumseh FTW!
Oliver springs,Tn
it appears the moving sheave of the driver has a black ring around it. and it where its been rubbing against the belt to much? but the clutch hardly engages as i ride?
B man
Tecumseh FTW!
Oliver springs,Tn
ok i figured part of it out. bad alignment. i just checked again and there a good almos 1" out of align. and i need to clean my driver.
Blazkowiez
Kart Aficionado
Houston, Texas
Those karts have a HORRIBLE deck btw. With only 2 supports for the motor it all twists and needs to be re-enforced. Please make sure that isn't too bent.
ok. i wasnt sure if one side was more slanted than the other.
It's either a lot, or nothing. Asymmetrical belts are very asymmetrical, one side of the belt is at 2*- almost completely flat. The symmetrical belts are dead even on both sides- there's not a slight difference so orientation doesn't matter.
Recently, someone posted a pic of a symmetrical belt with orientation marks. Don't let this fool you, it was a factory goof.
