centrifugal clutch spring?
the-cyborg
Spring, Texas
Hi to all, Were can i get a stiffer centrifugal clutch spring? Thanks
What brand and style clutch? also pictures of your setup would be helpful. That being said, why are you needing stiffer springs, are you looking for a delayed engagements for idling? Just an FYI Jim over at Max-Torque can custom make you a clutch for just about any application or RPM range. see my sticky on custom clutches for contact info.
island
Guam U.S.A
Guam U.S.A
This is the clutch a Comet 1" bore, #40/41 chain, 10 teeth clutch. The Comet SCS 400 series clutch With heavy duty needle bearings. it says Approximate engagement of 2000 rpm. I read a couple of thread here that when they degovern there engine there clutch bites due engine reved more then normal on idle. I have a GX390 I would like to degovern.
[/IMG]
r_chez_08
Should be in the shop...
Cornwall, UK
Degoverning alone will not cause a higher idle. If it does then you haven't setup the throttle correctly.
kendelrk
redneck engineer
westland michigan
i used the same clutch with an ungoverned gx200 clone with no problems at all at 2200 engagment, i beleive stock a gx390 idles about 1400 rpm
